Non-Urgent TOPS Requests
55002
16 Aug 2019
Ldn
I didn’t spot any of the Numbers you have suggested. I went down past Roberts Road, to Mexboroug, they was just 69010 outside the works. Very quiet for Robert’s Road. It really could be one of the Numbers you have mentioned.
312 was only one there, the other 2 were at Longport apparently.
313 arrived from Loughborough on the 14th
SEtrains
29 Jan 2024
Greater London
Does anyone know what is on this?
And this?
Thank you
Spartacus
25 Aug 2009
And this?
Thank you
37884
55002
16 Aug 2019
Ldn
0
And this?
Thank you
0E26 was 37608, which is taking 93001 to Long Marston on 0Q67
mkrobins
26 Mar 2019
Good morning all,
Could anyone help with what's on 0Z40 1355 Reading Triangle Sidings - Reading Triangle Sidings today please?
Thanks very much in advance as always,
Cheers,
Mkr
NorwichThorpe
13 Jun 2024
Brighton
Use this (Real Time Trains) and change the date, shows you freight trains through Hove. Anything with a Q code runs as and when required
Thanks that's a really good site. How times have changed.
Peter
JKF
29 May 2019
0Z51 0940 Portbury Automotive Terml toSwindon
Believe this was a route learner for the short term steel contract (which also ran today!) so likely a DB 66, but the routing was a bit strange.
Roger B
16 Jun 2018
Gatley
I'm after 153384 (57384) and 153385 (57385) in departmental service. They don't seem to be at RTC Derby whenever I go past, so I'm wondering where they're generally based, and if they run under particular headcodes that I can search for in RTT, or indeed any other way I can keep track of them. if anyone can shed any light, that would be very helpful - many thanks.
Spartacus
25 Aug 2009
66050
55002
16 Aug 2019
Ldn
Hi all,
Could anyone tell me what 0M57 and 6U84 both are please
TIA
0M57 is 37608 going back
Can anyone let me know what 59104 been up to today also how did 66951 get to Acton this morning please
25 Apr 2020
Dorset
66951 was on 7V50 1421 Wembley Yard to Merehead if that helps at all,
sadly didnt see 59104 all day.
Trainz6013
4 May 2024
Earth
Morning all, does anyone know what is running 6Z90 Tyne SS to South Dock Port Of Sland, setting of at 08:10 today please? If you could tell me the stock it's pulling as well that would be grand :)
RobK
13 May 2024
Does anyone know the ID of the 730/2 and hauling 37 which ran this morning from Oxley to Belmont down yard this morning running as 5Q23.
Many thanks
800001
24 Oct 2015
Many thanks
730205/222 Oxley-Belmont, no idea of loco.
Sun Chariot
16 Mar 2009
Hello - if any forum reader saw this, or can enlighten me, I'd appreciate it. I'm not local to its route. Many thanks.
Today's 5M26 Cross Country ECS 05:10 dep from Eastleigh TRSMD to Bournemouth? Data received into RTT showed a 13-car set of Voyagers (220 + 221 + 220). Link is below:
It's a weekdays service; the previous five paths have been 2 units (of either class); and so I'm a little sceptical of a 13-car.
Thanks in advance
Spartacus
25 Aug 2009
Thanks in advance
Just looks like 003 & 006 to me.
Hi All, could anyone tell me the 66 on 0Z80 this morning. Much appreciated in advance. Thanks
66560
Liam L
19 Jun 2020
Good Morning, just a little request so I know if they out and about today and where they are planned to finish this evening.
Any ideas on 323203 & 323241 for today?
Thanks in advance
