"Loan" is questionable in someways, as both TOC's although seperate franchises are operated by the same company "Arriva". Probably happen again I suspect
So what are the chances of a Welsh 158 or a 175 coming over to ARN for a brief period?
Not much chance of a 175 working for Northern - no drivers "know" them. And I think that many Northern drivers will also be unfamiliar with 158s.
What about any remaining Piccadilly and Blackpool traincrew who worked/signed 175s when they last worked that way?
They won't sign them anymore, it was ages ago- 10+ years?
Even so, how long can traincrew go without working a unit type before having to be retrained and passed out again on them?
Not that long ago. There were still 158s working for TPE 10 years ago and they went before the 175s. Even so, how long can traincrew go without working a unit type before having to be retrained and passed ou00t again on them?
Rule of thumb is six months and then the traction type is normally removed from the traction knowledge card. However before a decision is taken on what might be required to officially restore that knowledge a training needs analysis would take place, the outcome of which would not be the same for every situation.
......that would indeed be a major issue. ERTMS is switched on in ATW 158s even when running away from the Cambrian (it still monitors things like the trains speed, intervening if it goes over 90mph).The problem that would arise from ATW 158s being loaned to Northern is the revised cab layout following fitment of ETCS equipment. Note however that ATW 150/2s have been loaned to Northern in recent years on at least two occasions without issue.
It appears some posters have forgotten that there are plenty of Northern traincrew working 158s everyday. The problem that would arise from ATW 158s being loaned to Northern is the revised cab layout following fitment of ETCS equipment. Note however that ATW 150/2s have been loaned to Northern in recent years on at least two occasions without issue.
Had not forgotten - but it is mainly "Yorkshire"-based services that use 158s - they don't go to Liverpool or Manchester Piccadilly on Northern services. Nor to they appear on Newcastle-based services. Their only appearances on the "Lancashire" side of the Pennines are on Calder Valley & York - Blackpool services.
