To a novice like myself. ThanksJust on the back of this. Can anybody explain the difference between an enhanced and a standard pass?
Emilali, do you know when this changed? From my understanding, they used to ask for Standard?Enhanced.
Thanks, didn't realise that.Changed to enhanced in April.
Thanks. I'm in a strange position.. I first applied for Northern in 2019 when they required a standard pass.No they would ask you to resit them to meet enhanced standard
Thanks L401CJF, that makes sense!Each TOC that uses enhanced uses their own enhanced mark, ie there isn't a national standard for enhanced, its down to the TOC. Say for example a standard pass is 85% (i don't know what it is). TOC A might have enhanced for them down as 90%, for TOC B it might be 95% etc.
You may well have met the mark for an enhanced pass for some TOCs last time hence why you've not been asked to resit them.
Thanks 60074, much appreciated!I’m aware that if you passed to national standard before April 2020 (when they changed to enhanced), that Northern will honour your national pass and not make you resit.
Any paper tests that need passing or completing will have to be done to enhanced standard. However, I have been told that for the computer tests, Northern are just national standard.
Once again this falls down to every TOC having their own individual “enhanced” standards.
Just to be 100% clear, if you passed everything to standard pre April 2020 you won’t be asked to resit? Thanks in advanceI’m aware that if you passed to national standard before April 2020 (when they changed to enhanced), that Northern will honour your national pass and not make you resit.
