Nottigham Express Transit
Comstock
19 Jun 2012
The NET is losing a million pounds a week apparently....
http://www.bbc.co.uk/news/uk-england-nottinghamshire-42719544
Tramlink Nottingham's annual report showed the company was losing nearly £1m a week in the year up to March 2017, despite 15 million passengers using the service during that period.
Tramlink Nottingham said the loss was due to an impairment charge, but turnover increased by more than £15m.
The annual report shows losses of £48.51m, despite passengers numbers rising from 11.5 million in 2016....
Goldie
29 Sep 2014
That is some astonishingly poor reporting. There's no attempt on the part of the BBC to work out whether financial losses are a) what was expected by the franchisee; or b) bigger than expected but still manageable; or c) a sign that a Metronet style collapse of the franchisee is about to happen. There's no attempt to explain what an "impairment charge is". I assume that the losses are largely caused by servicing the debt incurred during construction, but you can't tell for sure from the report...
kevjs
4 Sep 2013
http://www.nottinghampost.com/news/business/tram-operator-reveals-more-details-1082577 has some more details - not sure what that means in English but it seems to be expected in the main.
A Tramlink Nottingham spokesman said: “In common with any Private Finance Initiative (PFI) concession, the level of interest payments on initial commercial lending used to fund new infrastructure delivery is profiled throughout the course of the contract in accordance with agreements with the lenders.
“This is the case here and the concession’s commercial debt reflects the front end construction and infrastructure costs incurred in completing the two new tramlines and buying new trams.
“Clearly the expanded network is now operating successfully and is fully financed for the duration of the concession...
317 forever
21 Aug 2010
North West
I realise that Nottingham Trams have basically 2 overlapping services: Hucknall - Nottingham - Toton Lane and Phoenix Park - Nottingham - Clifton South.
Do the Incentro trams (201-15) and Citadis trams (216-37) work both lines, or does 1 batch keep to 1 line and the other batch to the other line?
My aim is to ride both modern southern extensions once using opposite tram types.
DriverToBe
10 May 2015
Both types are used on both lines.
route101
16 May 2010
Used the Nottingham tram last Thursday . First time in Nottingham , nice city and smaller compared to my hometown of Glasgow . Rode 3 branches of the line , Hucknall , Phoenix Park and Toton Lane . Did not have enough time for Clifton South . Was impressed by the bridges at the railway station and hospital . When at old market square stop someone asked me if i was a spotter and advised me of a tram FB group .
jfowkes
20 Jul 2017
Here's a question about the Nottingham trams:
Between Wilkinson Street and the Forest, the northbound and southbound lines split up and essentially follow two parallel roads. I assume this is because there was insufficient space to run both tracks in parallel.
But, the northbound line runs on the easternmost track and the southbound on the westernmost, which means the two tracks have to cross each other at both ends of this section.
Any idea why they did this? It seems like there must be a good reason, as it introduces conflicts that wouldn't be there otherwise.
Peter Mugridge
8 Apr 2010
Epsom
Are the roads in question one way streets?
I've been along there quite a few times but never thought to check something like that!
bluegoblin7
10 May 2011
JB/JP/JW
Yes, one way, I understand.
Noel Street (Forest to Wilkinson Street) is one way with the trams running on a reserved contraflow.
Radford Road (Wilkinson Street to Forest) is two-way traffic with the trams running on street.
jfowkes
20 Jul 2017
Ah, I see. Should have looked at the map more carefully.
Noel Street is one-way, but reverses the one-way direction at a junction half-way along it. So the tram is only contraflow for half of it.
OwlMan
25 Jun 2008
Bedworth, Warwickshire
A car seems to have ventured off the road onto NET tracks
BBC Here's the car that has ended up on tram tracks in Nottingham - leading to services being halted between the University Boulevard and NG2 stops.
NET, which runs the tram network in Nottingham, said a recovery vehicle was removing the car.
jfowkes
20 Jul 2017
It happens every few months on that bridge, despite all the warning/no entry signs. Apparently some satnavs don't understand it's tram only - and nor do some drivers.
duffield
31 Jul 2013
East Midlands
The road layout is very poor. Obviously the primary responsibility lies with the drvers but when they were building this section my first thought was 'drivers will regularly drive up the tram track'.
Ideally the road should curve/move to the left and then to the right before this point, then the correct route could be straight on at this point (instead of 'straight on' leading to the tram tracks), but that would have required some land take and possibly a building demolished/moved and would have messed with the on-road tram alignment.
Maybe some sort of flashing stop sign could be triggered if a car enters the offroad section? The first section is fully paved and you could easily reverse off of it, but this vehicle have gone past that onto the 'railway style' section and got stuck. You could extend the paved section a bit as well to give extra stopping distance.
jfowkes
20 Jul 2017
Those automatic bollards they use to only let certain vehicles into pedestrianised areas/bus lanes would work? Just lower then when a tram approaches.
duffield
31 Jul 2013
East Midlands
Potentially very dangerous if they develop a fault and rise under the tram. And if someone does drive into them they'll probably get stuck in the up position and cause a much longer service disruption than the current situation where the car is just lifted/towed off the tracks.
Maybe a holographic barrier would work? :E
whhistle
30 Dec 2010
Nottingham Express Transit has released a statement stating apologising for any inconvenience..
Not sure why they should apologise.
It wasn't their fault?
Just creates this default "anything wrong, say sorry but it means nothing, thus there's no point in saying it" culture.
"We're sorry for the litter... that you dropped... on our floor"
Ken H
11 Nov 2018
N Yorks
I have been on NET a few times. The standard fare is extortionate if you are only doing a couple of stops. I sometimes stay at the premer inn in Goldsmith street, tram stop outside. It was raining and I wanted to get from Lacemarket, just 3 stops. But it was still over £2. Same as going all the way to the terminus.
It also seems to dawdle. They need to speed things up a little, especially the stops.
You should have got one of these.
https://www.thetram.net/short-hops.aspx
Our City sHOPper offers travel between Nottingham station and Nottingham Trent University for just £1 each way.
jfowkes
20 Jul 2017
spinba11
There is no service between Meadows Way West and University Boulevard due to a car stuck on a bridge no prize for guessing which bridge, how much road is there after the no entry sign and before the road ends?
jfowkes
20 Jul 2017
Measuring on google maps: from the stop line at the lights (the point at which the road turns right), there is 21m before the no entry point, then another 26m before the tarmac runs out altogether.
spinba11
You need to be a special kind of stupid to actually get stuck on the tram lines, there is enough leeway to allow a genuine mistake but to continue the full 47m? I’m sorry but if you end up on the tracks you shouldn’t be driving
Jozhua
6 Jan 2019
Agreed! If they're so desperate to go on the bridge maybe they should be taking the team...
