objects landscape diplaced
gerardw
13 Jul 2006
Hello,
I've installed the new BVE4 and all the things I need to install...
When I install new routes, the objects of that route and the railway are all on a wrong place, I see houses in the air, railways are going steep downhill, signs are placed far away of the railway,...
All is "normally" installed at the right place...
I also get a lot of errors, I have to "ignore" it to play the game...
Can anyone help me please...
Greetz
Gerardo
LabRatAndy
4 Jun 2006
Gerard,
You may need to set the decimal seperator to be . (dot) rather than a comma. As this cause may strange errors like you describe, hope this helps.
gerardw
13 Jul 2006
Thank you very much, you all...
I will try to find it out, if it doesn't help, i will let you know...
Thanks
G
[EDIT]
Yes, I did it,
When I changed the decimal sign, there was an error so I also changed the language to English UK and now it works just fine!!
I am glad to finally see what the new bve4 is all about, they done a nice job with the trains also!!!
Thank you very much for your support!!
Greetz from Antwerp in Belgium
Gerardo:glasses2:
Coxster
9 Jun 2005
Glad you've got it working. I hope you enjoy the program and the fantastic add-ons available.
Unfortunately there are no Belgium routes listed on http://bve-routes.com which probably means there aren't any available.
