Objects over 25m in BVE
Nick
8 Jun 2005
How do you create objects over 25m in BVE that do not disappear after you have passed 25m of the object, say if you have a 35m building, I presume you build 25m of this, then 10m of it and place them next to each other to make it look like the full 35m building?
Tom B
27 Jul 2005
If you had a 35m building, you could build it from -10 to +25m.
9 Apr 2006
London, UK
If the object is longer than 25m, you should code it negatively. Lets take your building for example, instead of coding it like this,
CreateMeshBuilder,
AddVertex,-5, 0.6, 0,
AddVertex,-5, 6, 0,
AddVertex,-5, 6, 35,
AddVertex,-5, 0.6, 35,
AddFace,0,1,2,3,
GenerateNormals,
You code it like this.
CreateMeshBuilder,
AddVertex,-5, 0.6, -35,
AddVertex,-5, 6, -35,
AddVertex,-5, 6, 0,
AddFace,0,1,2,3,
GenerateNormals,
Afterwards, you will need to place the building 35m ahead of where the building is suppose to be- and the building should be at the right place without disappearing when you travel 25m.
