I'm very confused about whether I can get this train using my off-peak open return or not,
The website is correct, in that if you search for a Bexhill to Bangor journey, an Off Peak ticket from Bexhill to Bangor is valid on any train between Bexhill & London, and restrictions are only applicable between London & Bangor.
However, a Bexhill to London ticket is a different matter entirely. But if that's not the ticket you hold, you don't need to concern yourself with that
I don't anticipate you will have any problems, but just in case you encounter one of the staff who do not understand the Network Area Rule, you could print & bring an itinerary from the National Rail website. I have heard of a small number of people be incorrectly excessed in this situation, it's unlikely to happen, but where it does, I will certainly be willing to help by proof reading a letter of complaint and will do my best to make sure that any incorrect charges are refunded.
Ticket Conditions said:
NETWORK AREA
Off-Peak tickets for journeys
starting within the Network
Area to destinations outside
the Network Area with travel
via London are valid by any
train to London, to connect
with trains from London.
I'm pretty sure I booked an open return
Not quite, but I can certainly see how the confusion has arisen!
You may recall the days of the Open Return as an unrestricted ticket type, both the outward and return portions were valid for one calendar month.
However the term "open return" started to be used by websites such as Thetrainline.com to refer to any ticket that was not a "booked train only" ticket, ie a restricted ticket that was only valid for a day was still considered an "open return", not just the ticket type "Open Return"!
So, there was much confusion. In 2008, the ticket type Open Return became Anytime Return. These days, the outward portion of an Anytime Return is (only) valid for 5 days.
However, you don't have an Anytime Return, you actually have an Off Peak Return, which is the new name for what used to be called a Saver Return.
So, these days, the term "open return" is effectively meaningless, and no-one can
quite agree on what it should mean (but that discussion is for another day!), I suggest avoiding the use of the term, to avoid confusion.
and my ticket from Bexhill to Bangor says it's valid until the 28th April, but I have a ticket from London to Bangor that is a seat reservation for 4th April. Does it matter if I just don't get this train and go tomorrow instead?
Your outward journey must commence on the date shown on the ticket, although it can continue into the second day if you stay overnight (e.g. you could depart Bexhill in the evening, stay overnight, and take a train the next morning from London to Bangor)
Also when I look at my booking online it says my return journey is on April 4th and doesn't say anything about an open return! I'm so very confused!
The return journey must commence within the validity period shown on the return portion of the ticket, you are not tied to travelling back on any particular day.
(it can get a bit complicated if you were to return on the very last day of validity and have an overnight stay but that doesn't appear to be applicable here so I won't go into that!)
