156418 said:
Its your standard end of line TPWS setup.
Rail Grinders have been working at Sudbury Station all week, they've totally removed the Zig-Zag Weld along the entire section which could be a factor.
AFAIK, the zig-zags are somthing to do with the track cicuit, so I doubt they would have anything to do with it, though I suppose they could also increase friction, causing the unit to stop with a lesser brake application - but there again, wont the grinding also give the rail head more friction - making it easier to stop?
156418 said:
The East Anglian Daily Times have devoted 3 pages to it, even wheeled out a photo of a crappy 121 back in 1999 approaching the station (although they've mis-dated it as 2000)
I think perhaps they could have added the caption under that one "it would have been worse if these junk were still in use"
Well, 156's are probably the best 2nd gen dmu built, however most enthusiasts would give anything for a 121 any day!! God knows why you dont share that opinion - but everyone has their own views!!!
And besides, at least if you are in a collision and your in 1st gen, there are loads of doors to escape from, whereas in a 156, if it caught fire - you'd be rather hot...... and that goes for any of the modern rubbish which are supposedly safer, but when you read between the lines, are actually not that safer than the 1st gen stuff..... Yorkie knows much more on that subject than me, has he has done lots of reseach on the matter.
METCAM.
