So would they eventually want to reconstruct to create two islands as at future Piccadilly?
I'm not sure how that would happen with the main entrance and main Piccadilly bound platform having all the retail, circulation space etc....
I remember the old Fairfield St entrance. Very narrow steep steps, certainly not DDA friendly.One would hope that they can include an entrance in the plans as 15/16 will be a long trek from the main concourse or even from the satellite lounge.There is an entrance complex on Fairfield Street which is far better than the meagre provision that was previously provided.
Been there, done that! It's a handy shortcut from the Metrolink platform - when the lift is working.There is a lift from the "taxi" area on Fairfield Street straight up to the satellite lounge (and P12). I've often headed for that when running late for a P13 departure, although once it wasn't working and it's a long way back round the other way
Not as far as I am aware. It is probably too early for detailed drawings
AFAIK not much space is available to build the Ordsall Chord. I expect it will be an engineering miracle.
That possibility was covered in the Manchester Hub study report but no options were proposed.Not a clue, but I'm hoping to whatever is up there that there is going to be a degree of grade seperation at the junctions, hopfully Victoria - Chat Moss going over the top of the lot on a flyover, as that has the biggest approaches to climb and fall from, and will see the most services.
Will the former Liverpool Road station that is now a museum lose its rail connections to the national rail network once the Ordsall Chord is completed. Surely that fact will have been established by now.
Not saying it couldn't happen but everything published so far suggests that any grade separation work would be on the existing Victoria-Chat Moss line, not the new chord.Depends on the route. The shortest, a simple chord between the Deansgate and Salford Central lines, would cut the link into Liverpool Rd. An alternative layout would leave the Deansgate to Salford Crescent line to the south, then climb and turn north to fly over that line and the line to Salford Central, before descending into Salford Central.
