RJ
I've been looking at the official Tube map (the version with NR lines included) which shows where all Out of Station Interchanges are in London. Given the rule whereby travel by bus breaks OSIs, a couple of them surprised me;
Bromley North to Bromley South
Kent House to Clock House
The first one in particular is a long walk and with almost a dozen buses running between them, I wonder if there is any facility in place for a special OSI which allows the use of a bus.
One thing I did note was the lack of an OSI between Warren Street and Euston Square. Outside of Central London, the majority of OSIs are in the north eastern quadrant of London. I wonder if they are well used and if they go some way towards explaining the relative paucity of orbital bus routes in this part of London.
I like random bits of trivia about London's transport network and also had a look at the route validators which are also shown on the map.
There is one in Zone 4 (Richmond) and one in Zone 5 (Rayners Lane.)
Route validators are primarily advertised as a way to save money on routes that are defaulted to pass through Zone 1. In the case of those validators though, can they be used to alter fares where the default route is not passing through Zone 1?
Use Tolworth to Kew Gardens for example. The default route appears to be priced for a Zone 2-5 fare, but a reasonable route exists involving Zones 4-6, NR Only via New Malden and Richmond which is not shown in the Single Fare Finder. Are the pink readers not set up to calculate other zones that can be avoided other than Zone 1?
In a similar vein, the default fare for Tolworth to Richmond is for Zones 2-5, despite a single change being available at Raynes Park allowing a journey passing through Zones 4-6, which is cheaper. Reasonable?
Whilst I'm here, the dual zoning of Hoxton intrigues me. From what I can see, being in Zone 1 only benefits people whose journey is Hoxton to Shoreditch High Street and vice versa. I say so as there are no OSIs or interchanges at either station which would affect fares for anyone travelling from anywhere else. Neither are there nearby stations that are dual zoned (looking at Whitechapel here) so I can't see any obvious impact for anyone travelling from anywhere else in Zone 1. There tends to be a reason for everything - any ideas about this one?
