phil1960
Hello.
Basically the ticket I bought yesterday was CDR Boundary Zone 3 to Reading via Slough = restriction code W1:
http://www.brfares.com/#faredetail?orig=0042&dest=RDG&grpd=0403&rte=801&tkt=CDR
And for completeness, I was using Zone 1-3 Travelcard on Oyster to travel from Paddington. I was also using a Staff Travel Card to reduce the fare, but that had no bearing on the validity of the ticket. Scrutiny of the restriction W1 shows that this doesn't bear any PM restrictions from Paddington as applies to the one from London Terminals to Reading via Any Permitted = restriction code J9:
http://www.brfares.com/#faredetail?orig=PAD&dest=RDG&grpo=1072&grpd=0403&tkt=CDR
My plans were to jump on the 17:42, but barrier staff refused to let me through. I could understand why they first said no as it was restricted as per J9 and clearly advertised to that effect on the CIS screens. They did not show any willingness to check or back down despite my ticket was valid, surely?
Back to the ticket office to see if they instead could confirm the W1 restrictions and possibly print them out was met with a "No, wasn't possible". That I find hard to believe.
I simply couldn't be bothered about trying all over again at a different gatelines for other trains up to 18:03, so as a result just waited for the 18:05 which was the first fast service I could possibly get on without any hassle.
It wasn't the 20-odd minute delay that bothered me, but the fact if a ticket restriction is issued then staff should at least have the courtesy to check, apologise if they were wrong and let me on.
So, whilst staff probably go into auto-pilot mode for restriction J9 that time of day, can I assume this was a staff knowledge and subsequent customer service issue? It does seem odd that code W1 exists and applies for fares from zone boundaries as quite obviously J9 is put in to keep off peak tickets off busy PM services out of Paddington.
I've emailed GWR but understand issues with Paddington gateline staff are not uncommon.
Regards
Phil
Regards
Phil
