Permitted routes for Crewe to Macclesfield
yashicamat
3 Mar 2012
Hello,
Apologies for having to ask this; I've tried and tried to get my head around the Routeing Guidelines but Macclesfield doesn't always appear where I need it to (and I can't fathom out if it forms part of a 'station group') . . . it is getting very complex! Then there's easements etc. which make things even more complicated.
My understanding at the moment is the obvious routes are;
Crewe - Stockport - Macclesfield
Crewe - Cheadle Hulme - Macclesfield
Crewe - Kidsgrove - Macclesfield
Crewe - Stoke-on-Trent - Macclesfield
My query is if Crewe - Stafford - Macclesfield is a permitted route? It appears as an option when entering into national rail enquiries (usually for the late evening), but with a higher price attached to the ticket. If it is a permitted route, surely it should be valid on the standard 'Crewe - Macclesfield anytime' ticket?
Any help is greatly appreciated.
Thanks
Rob
SS4
30 Jan 2011
Macclesfield and Crewe share a routeing point so the permitted route is the shortest route by distance (+3 miles) or a direct train
According to Railmiles going via Stafford is 63mi 43ch
The shortest route is:
Code:
Distance: 22mi 04ch - show the route on a map
Route: Crewe, Crewe South Junction, Crewe North Stafford Junction, Barthomley Junction, Alsager, Kidsgrove, Congleton, Macclesfield
yashicamat
3 Mar 2012
Thanks for the reply. I don't quite understand your remark about distance; Stoke is a permitted change as is Kidsgrove, but Stoke is significantly further as a station change; likewise, Cheadle Hulme is closer than Stockport. But the two major changes often represent a quicker overall journey. Or is this something to do with the easement surrounding Kidsgrove?
Thanks
Rob
SS4
30 Jan 2011
There is an easement that permits travelling via Stoke.
30106 Journeys from Macclesfield, Congleton, Kidsgrove and Longport via Stafford may travel via Stoke on Trent. This easement applies in both directions.
My interpretation regarding Stafford in that easement is that it's talking about journeys from Longport via Stafford rather than via the other stations
I can't get NRE to offer me a single ticket for Crewe to Macclesfield via Stafford
yashicamat
3 Mar 2012
Thanks. The ticket I've seen (this is commuting, so for me on weekdays) is the 19:55 from Crewe (on Monday).
Is it a reasonable assumption if National Rail Enquiries gives the journey between two stations (and the passenger holds an anytime/any route ticket between those stations), it should be a permitted route?
SS4
30 Jan 2011
It would be but NRE says you need to buy two tickets to make that particular journey which is why it costs more than the other tickets. That you need two tickets makes it not permitted.
NRE does not sell ticket itself, if you look at the London Midland site it does not show the 1955
yashicamat
3 Mar 2012
Got it :)
Thanks for the help, much appreciated!
Rob
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
I don't agree that NRE is interpreting the easement like this; the electronic version of the routeing guide makes it clear that "via Stafford" applies to all four origin stations. In any case similar easement 30105 seems to be what's allowing the journey via Stockport:
Easement 30105 said:
Journey from Macclesfield, Prestbury, Adlington, Poynton and Bramhall via Wilmslow may travel via Stockport. This easement applies in both directions.
This is probably combined with
Easement 700074 said:
Customers may double back when travelling between Cheadle Hulme and Stockport.
There doesn't appear to be an easement similar to 700074 that would allow doubling back through Norton Bridge, which might be why the route via Stafford isn't permitted.
I'm otherwise baffled as to why NRE allows Crewe to Macclesfield via Stoke-on-Trent. It doesn't appear to be a permitted route.
martinsh
27 Jan 2011
Considering a move to Memphis
I wonder if it's something to do with the fact that until recently the Manchester - Stoke local service only went as far as Macclesfield outside peak hours, so Crewe - Kidsgrove - Macclesfield wasn't a feasible option for most of the day.
Paul Kelly
16 Apr 2010
Reading
That's a reasonable explanation, but I meant more in a "mechanical" sense, having worked through the routeing guide and easements and timetable I can't see what's in there that's making IPTIS (the journey planning engine behind NRE) allow it.
SickyNicky
Verified Rep - FastJP
8 Sep 2010
Ledbury
Just to clarify, Norton Bridge is a member of the Stafford group routeing point, so doubling back between it and Stafford is permitted for interchange purposes.
Paul Kelly
16 Apr 2010
Reading
Good spot; well I'm even more confused then. Clearly not a routeing guide expert yet...
NRE_Kathryn
17 Feb 2011
Hiya, came across this thread whilst doing some reporting this morning. Did you get to the bottom of the issue, or would you like me to investigate?
Paul Kelly
16 Apr 2010
Reading
Hello NRE Lisa, I don't think this one is a major issue - see the "Peterborough to Whitehaven" thread for something more detrimental to passengers for example!
