Physics Question
E_Reeves
25 Oct 2015
West Midlands
Hi all,
I had my last proper GCSE today, which was Physics. Most of the paper wasn't too bad, but I came across a question where I'm not sure if I'm incorrect or not...
The question: Driver C travels at 32m/s on the road and then stops. The car has a mass of 1200kg. Show kinetic energy stored at 32m/s is 614,000J.
I then do the calculation using the equation: kinetic energy = 1/2 x mass x velocity^2 and I got a result of 614,400J, not 614,000J. I'm not sure if I went wrong at all but some of my friends also noticed this too.
What are your thoughts on this?
gnolife
4 Nov 2010
Johnstone
Hi all,
I seem to recall that the instructions on the front of the paper included that unless otherwise statied, answers were to be to 3 significant figures
I will add that I did my GCSEs in science 10 years ago now, so my statement may be outdated.
433N
Guest
20 Jun 2017
You are right ... and the paper should have been proof read to ensure that this kind of confusion could not arise.
(It is possible that they could argue that they are justified in stating the answer as 614000 on the grounds of significant figures but at no point in the question is this specified or implied implicitly - unless there was some statement to the effect that all figures are to 3 significant figures on the front of the paper or something - but then 32 should be 32.0 : ON EDIT - written before the above post. I would still argue that writing 32 is accurate to 3 significant figures is a nonsense).
This sort of thing happens far too often these days ... too little scrutiny at the time the paper was prepared.
E_Reeves
25 Oct 2015
West Midlands
It's not the first mistake in these exam series as well. There have been a few others but luckily they were identified by the exam board and they sent out an erratum notice for it. It should not happen, especially considering the amount of time they've had to prepare this exam...
I don't recall seeing anything about significant figures on the front of the paper.
SS4
30 Jan 2011
Your answer is correct and as far as I can tell it comes down to significant figures - in a calculation you should always round your answers to the least precise value. However, if this were the case here you'd have 610,000 as both mass and velocity are 2 significant figures.
No doubt it's a poorly written question though - it should never be merely assumed that 3sf is the correct rounding
E_Reeves
25 Oct 2015
West Midlands
I did put ~614,000 after my calculation though so hopefully I'll get the mark. I should definitely get the mark for using the correct equation anyway, but there's not much I can do about it now, I suppose.
433N
Guest
20 Jun 2017
To be fair, we don't know how many significant figures the mass is accurate to but, like you, I would assume that the velocity is accurate to 2 sig figs which would limit the accuracy of the answer to 610,000 ( 2 s.f.) .
Unfortunately, at almost every level including university, significant figures and accuracy are introduced and it is stressed how important they are. Then the person introducing them will lazily use arbitrary numbers (often 10 minutes after introduction) with no regard for them. The use of sig figs requires extremely careful (pedantic, even) thought and few have the rigour or self-discipline (or nerdocity) to use them correctly and consistently.
E_Reeves
25 Oct 2015
West Midlands
We were taught to put the full answer unless the question said to do otherwise. If there were many decimal numbers then I'd round to 2 decimal places, but I wouldn't personally use SF unless told to specifically.
TheNewNo2
31 Mar 2015
Canary Wharf
Your answer of 614,400 is correct. As stated by others, the issue is likely that the question is applying a rounding without stating so explicitly, which is on them. If we assume the mass is accurate, then their 614,000 value gives a speed of 31.98958 m/s, which is 32m/s to 5sf.
I would say that this is why you should study pure maths - they stop asking you to show things to a certain number of decimal places and instead just tell you to prove something, and the answer will usually be expressed in terms of Pi.
433N
Guest
20 Jun 2017
... or a surd.
You know when you're getting serious in maths when you're not allowed a calculator in the exam. 8-)
Strangely, many people think Maths is all about numbers. :rolleyes:
D365
29 Jun 2012
Trouble is, they either state the 3SF on the front page, or not at all, and rely upon the teacher to point this out.
northwichcat
23 Jan 2009
Northwich
I have a vague memory of Physics A Level saying to give all answers to 3 significant figures unless otherwise stated, while the Mechanics part of Maths said to 1 decimal place unless otherwise stated, meaning if you were asked for the force of gravity on a Physics paper you would say 9.81 m/s squared, but on the Maths paper you would say 9.8.
If that is still the case and the question just said "Find the kinetic energy stored at 32m/s" you would give the answer to 3 significant figures and I would have given it in KJ unless stated but it is stated to give the answer in J.
amateur
23 Feb 2014
... or a surd.
Wait until you have to study pure maths!
433N
Guest
20 Jun 2017
:lol:
I already have a degree in Maths (well joint Maths and Physics so I guess that I've pretty much done with my Pure Maths - my degree was mainly Applied).
I was being facetious ... I've even done quite a bit of numerical analysis and I'm pencilled in for some more on a Masters I've signed up for.
DarloRich
Fenny Stratford
Hi all,
My thoughts are that this has reinforced why I stopped having anything to do with maths after my GCSE exams which were about 400 years ago! Is to possible to have this explained in English? ;)
Surely you don't expect the English teacher to understand maths?
amateur
23 Feb 2014
:lol:
Group theory, number theory, topology, proofs ....they never told you about that at GCSE or a levels
PeterC
29 Sep 2014
After school I found degree level maths a foreign language and got a job in finance instead where I was dealing with real numbers. I ended up with a degree in geography and a career in computing and now dabble in music journalism.
DynamicSpirit
12 Apr 2012
SE London
I think this is the correct analysis. In this case, if the speed was given as 32m/s then that implies only two significant figures, so the answer cannot be given to more than 2 significant figures. Giving the mass as 1200kg seems like rather bad practice, because it's ambiguous how many significant figures are intended - two or four - but this doesn't impact on the answer when speed is already limited to 2 significant figures.
If the paper really did say exactly what E_Reeves has quoted, then a complaint to the examining board would seem warranted (but I'd probably want to confirm that's exactly what the paper said first).
E_Reeves
25 Oct 2015
West Midlands
I wrote it down in the exam on scrap paper, so I'm sure it's correct. I can ask to see the paper at school anyway, so I might look again
