Police called as commuter sits in empty first class zone on packed rush-hour train
hwl
5 Feb 2012
Yes, I appreciate that - you'd need to make sure other trains could take up the slack before you could do much.
Both LNWR and Northern are still in the early part of their franchises and Northern have enough issues on their plates dealing with adding extra capacity already...
Hence not a good time to be rethinking XC.
6Gman
1 May 2012
Agreed. The Voyagers are a disaster, sometimes mitigated by coupling two sets together to form a decent length train, from the customer's point of view. They epitomise the British mentality of maximise profit, provide minimal service and the customer can whistle.
Willing to pay a higher fare?
underbank
26 Jan 2013
North West England
Isn't the real problem the lack of consistency between TOCs and even between guards/train managers in each TOC. This guy has been allowed to sit in first class previously when it's been busy - why different this time? There should be clear rules as to when it's allowed and it should be policed/supervised consistently.
I suspect/suggest he means he has sat in First before without being challenged. That isn’t necessarily the same thing as being allowed...
Darandio
24 Feb 2007
To be fair we don't know this, unless i'm missing part of the news article it doesn't say anywhere that he has been allowed previously, only that he has done this before and there hasn't been an issue. Maybe that is because he was never caught until now.
I resent most strongly when I pay extra for First Class, and then somebody who hasnt paid that extra thinks that he has the right to be there
I do as well, but in the event of severe overcrowding the most sensible thing to do is to declassify and give me a partial refund, which is what LNR does on particularly busy trains.
Metal_gee_man
28 Oct 2017
If its not declassified then no standard fare paying passenger should be in 1st class!
Being a SE passenger I've been on quite a few services recently that have had 1st declassified due to overcrowding, but as always this is TM/OBM/TC job to make that call that their service is overcrowded, I will be the first person to jump at the opportunity to get out of cattle class in peak and get a seat!
So is it a TM / OBM / TC that makes the decision or must they ask permission from a controller to declassify and (potentially lose revenue)
Depends on the TOC. On LNR (and LM before it) it happens so often that it has to be guard discretion. Usually they wait until departure from Euston (so the majority of 1st passengers already have a seat) then announce it.
infobleep
27 Feb 2011
I’ve seen people being charged by a FGW RPI for standing in first class between Paddington and Reading. No doubt being first off at Reading was part of why the passengers did it. I have also seen people being charged for walking through into FC on the way into Paddington so they can be first off.
I thought it wasn't against the regulations to walk through. Or did they stop for long enough to class them as standing.
Then it leads to the question, how long does someone need to be stationary to be classed as standing?
infobleep
27 Feb 2011
Hard luck, the consequence of using public transport in a highly populated country where a large number of people want to travel at the same time is that you will have to stand. The alternative is don't travel at peak times if possible.
Is it hard luck that they put first class on a short train with no space?
As soon as you stop wilfully, I would say. Obviously stopping to let someone past doesn't count.
221129
21 Mar 2011
Sunny Scotland
On these services first class is at one end of the train. So there is no real excuse to be walking through.
farleigh
1 Nov 2016
There is a guide in the Guardian today on how to 'blag" a journey in First Class on a standard ticket.
Stigy
6 Nov 2009
Hopefully not as inaccurate and farcicle as the article the Eavenibg standard ran a few years ago about Penalty Fares :(
infobleep
27 Feb 2011
But it's not about excuses, it's about whether walking through is against the regulations or not.
tsr
15 Nov 2011
Between the parallel lines
Exactly what is the 'Eavenibg standard'?
Presumably a deliberate typo in the same way that many people rename the “Guardian” as the “Grauniad”.
(This is usually a comment against the editing and proofreading skills of the staff of a particular newspaper.)
AM9
13 May 2014
St Albans
How peurile.
43096
23 Nov 2015
If you are walking through first class coach H (as was) of an HST as it heads into Paddington, you’re clearly not heading to standard and the chances are you won’t be in possession of the required accreditation to access the next vehicle (the power car).
I believe some EMT crews have a neat solution when heading into St Pancras with first leading: they put a catering trolley in the corridor next to the kitchen area.
Stigy
6 Nov 2009
Or the Faily Wail/Daily Fail? :lol:
In my case, no. It was simply a typo as I’m using my phone to type.
mmh
13 Aug 2016
I don't understand why some people are in such a rush they walk through to the end of a train to get off, so I never have but there are perfectly reasonable "excuses" to walk through, you've just got on the train and the door happened to be in first class, or a reasonably frequent reason I have - to use the toilet.
I'll continue to have no qualms whatsoever about doing so.
AM9
13 May 2014
St Albans
OK, no problem. I find using phones and tablets for text entry prone to typos too.
The deliberate 'Grauniad', 'Torygraph' & 'Daily Wail' type of facetious misnaming is at best, boring and in many cases more pathetic than whatever the poster is claiming to be a failing of the target.
6Gman
1 May 2012
Walking through for a legitimate purpose is permitted e.g. where the First is in the middle of the train (Desiros), you're looking for the TM, you've boarded in the First Class section and you're heading for Standard etc.
It is not permitted if you are walking through in order to exit at the front of the train (e.g. on the approach to Euston).
mmh
13 Aug 2016
Where are these legitimate purposes defined? Am I allowed to use the luxury of the first class toilet?
