175001
With the 195 cracks, they'll be needed don't worry
Yes.Will
590P 1845 Manchester Vic.(Rev.Sdg) to Southport
Departing today be the NH 769 on the way to Southport?
Time will tell whether the different qualities of a DEMU with new diesel prime power give better performance than a 40+ year old traction system with a slushy hydraulic torque converter, especially once the drivers get to know them and have a free hand in controlling their different power characteristics.Will the 769 be able to keep up to the 150/156 timings ?
The Sprinters are hard pushed as it is to keep to time on the Southport line. Especially when it is required to stop at all stops.
The 769s apparantly have even poorer acceleration, at least in Diesel mode.
Hooray! We’ve waited long enough. I’ve got two days in Manchester next week and I look forward to trying them out.769434, 448, 431 and 450 all in passenger operation from today (as at 0200, Monday 17th May 2021).
Allocations as follows (ex-Southport);
2K81 0617 SOP-ALD - 769434
2K83 0815 SOP-ALD - 769448
2K84 0917 SOP-ALD - 769431
2K85 1016 SOP-ALD - 769450
3 years late running!Can confirm 769450 is out, just sighted on late running 2W02 0749 Alderley Edge to Southport.
Will admit I did doubt platform announcements when I thought what looked like a 319 pulled in on a Southport service, totally forgot about the 769s
Weren’t they targeted for 2017, or was it 2018?3 years late running!
Trains delayed through Stockport due to a pair of 331’s sitting down. No fault of the 769.769434 delayed out of Alderley Edgec currently 14 minutes late at Wigan Wallgate. Running well.
They sat down due to infrastructure failure.Oh the irony!
Well, the main issue comes from the fact that the DEMU only has two diesel engines generating 1000hp, while the 150/156 has four diesel engines generating 1140hp and is a lighter train as well!Time will tell whether the different qualities of a DEMU with new diesel prime power give better performance than a 40+ year old traction system with a slushy hydraulic torque converter, especially once the drivers get to know them and have a free hand in controlling their different power characteristics.
Nice to see the original n style still in place!769434 delayed out of Alderley Edgec currently 14 minutes late at Wigan Wallgate. Running well.
Sitting down = having half the pan carbon ripped off by some damaged OHLE. Thankfully no serious damage!Trains delayed through Stockport due to a pair of 331’s sitting down. No fault of the 769.
It actually a lot more subtle than simple Wikipedia data. The power transfer curve of electric generator + motor traction is totally different to that of a hydraulic transmission driven by a diesel engine. The two diesel engines only produce 1046hp between them at their output shafts, much the same as the class 150s which can only give 1144shp (shaft hp) from their combined efforts. It's what happens after that matters. A modern 3 phase generator will convert over 90% of its mechanical input power into electricity, and the engine can be run at its most efficient speed to generate that maximum power. The torque converter in a hydraulic transmission has a fairly restricted efficiency band and a lot of slippage when the load is stalled, (i.e. when starting from still) that wastes quite a large portion of the input energy. There are hydrulic experts here that can define the operation of a hydraulic drive far better than me. A traction motor however can provide maximum torque at very low speeds whilst the generator allows the engine to run at its optimum speed for power output. This is the main reason for all UK diesel freight locos being diesel electric.Well, the main issue comes from the fact that the DEMU only has two diesel engines generating 1000hp, while the 150/156 has four diesel engines generating 1140hp and is a lighter train as well!
Precisely, and although the available electric power from the diesel genset is less than the transformer output, the take off from Bolton platforms probably feels just the same, maybe a bit noisier.I was at Bolton today and saw the changeover on a few went smoothly as far as I could seeand there seemed to be no differance in running on electric from the pan or from the greaseburner underneath why should it its the same electric motors driving the train
All this adds up to far better control and use of the available output power, avoiding the noisy thrash you get when all that a sprinter driver can do is get the engine to stir the fluid up as fast as it can.
