Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
Anonymous10
19 Dec 2019
wales
Some must think that a constant stream of reports that blame every delay on the 769s' performance will give them a bad enough reputation that they will be replaced years before planned. They must be disappointed when they don't go wrong giving them nothing to complain about.
Please remember if the users are commenting from experiences in wales its with good reason, they are causing a nightmare there. I’m surprised they are better up north but also glad.
D9006
28 Aug 2019
Wigan
4 confirmed today by realtimes, units not confirmed by real-time for other 2 though, I try see if can make a visual on them
AM9
13 May 2014
St Albans
This thread is specifically about the Northern use of them.
craigybagel
25 Oct 2012
And some may think that the fact it's still newsworthy when they manage to get through a day with all 6 diagrams covered (which in itself only requires a not too taxing 75% availability) despite it being nearly 4 years since their original planned introduction date suggests there's still a long way to go.
AM9
13 May 2014
St Albans
As there will be for them. I doubt that they will replaced with 195s. Unless a diesel-electric or battery-electric bimode is delivered that can run on unelectrified lines but not contribute to CO2 or unnecessary local pollution under the wires between Bolton and Manchester, they will stay for the time originally planned, (ISTR 10 years).
507020
23 May 2021
Southport
Soon to be the wires between Wigan and Stalybridge. At this point it would probably be cheaper and easier to just electrify Wigan to Southport and have done with it. The 769s may be appearing reliable now, but this might have something to do with it being winter. Insufficient cooling isn’t as much of a problem in freezing temperatures outside, but will be again once it warms up.
AMD
6 Dec 2017
I saw 424 arrive on time to Southport at 9pm last night and can confirm that it wasn’t cancelled.
That was 450 you saw, I was at Wigan, saw what was up with 424 and was there when it got cancelled at Wigan.
507020
23 May 2021
Southport
No I saw 424. I have seen 450 more recently. What I am not sure of is that the day I saw 424 is the same one as it was supposedly cancelled.
Jamesrob637
12 Aug 2016
Fault on the 06:31 Stalyvegas to Southport today so the 08:16 Southport to Alderley Edge is starting from Manchester Oxford Road.
Greybeard33
18 Feb 2012
Greater Manchester
From December 2022, the Southport - Alderley Edge service is to be split at Manchester, with Piccadilly - Alderley Edge worked by EMUs. The Southport part of the service will terminate at Manchester Oxford Road.
From the draft Northern timetables (see link below), it appears that there will be interworking at Southport between the Oxford Road and Stalybridge services. Also interworking at Stalybridge between the Southport service and the Manchester Victoria shuttle. By my calculations, the full circuit, SOP - MCO - SOP - SYB - MCV - SYB - SOP, will take 9 hours, with lengthy layovers at Southport and Victoria. Therefore 9 diagrams will be needed for the Southport services, the same as the sum of the current Alderley and Stalybridge diagrams.
Assuming that the 769s remain on the Southport routes, with a daily turnout of 6 units, 3 diagrams will still have to be worked by 4-car 150 formations. Nevertheless, this saves one DMU, compared with restoring the Stalybridge - Victoria shuttle as a standalone 150 diagram under the current timetable.
If some of the TfW 769s were to be cascaded to Northern when replaced by new stock, all the Southport diagrams could be 769 worked.
47444
10 Aug 2019
Although a First In First Out at Southport does result in interworking the Stalybridge and Oxford Rd services, in fact not interworking them does not cost any more unit cycles.
SOP - MCO - SOP needs three units and SOP - SYB - MCV - SYB - SOP needs six.
Greybeard33
18 Feb 2012
Greater Manchester
Indeed so. Split diagrams might be less vulnerable to disruption in Manchester. Layovers at Southport would then be 23 and 61 minutes, versus 40 and 44 minutes for first in first out.
The Stalybridge services call at the intermediate stations under the wires between Bolton and Salford Crescent, whereas the Oxford Road services skip them. Therefore, in the interests of performance, it might be best to have all six of the Stalybridge diagrams worked by 769s, with three DMU diagrams shuttling between Southport and Oxford Road.
D9006
28 Aug 2019
Wigan
caught 769458 this evening at Manchester Piccadilly on 1950 Alderley Edge to Southport service and it was in diesel mode rather than 25kv , had to double check as noticed pantograph was down, run on diesel under wires , obtained a decent 71mph(using gps) on uphill climb from Salford crescent to Bolton but lost just under 2 mins on electric timings
AM9
13 May 2014
St Albans
That thread discusses a diesel - battery hybrid version of the 195. "Bi mode" usually refers to electro-diesel units that can draw electrical traction power from either the OLE or diesel generators.
Exactly, - a diesel-battery drive chain is almost the worst of both worlds, - it's only justification is the allow a non-emissive entry into a sensitive zone e.g. a city centre terminal. All the energy used to drive it comes from burning hydrocarbons to make CO2, - so it does nothing to minimise its impact on climate change. There aren't any serious charging facilities for battery trains apart from electrified sections of routes so unless the train has a pantograph and transformer in addition to its electric motored bogies, it's a completre waste of time.*
* If it has all three then it is a diesel-electric MU with a battery.
Peter Sarf
Croydon
I suppose the only Green bonus is if the batteries can be charged from the unit as it slows down.
Which they can. It also means the engines can be switched off rather than idling when not needed for traction. On trips with regular stops, this can produce fuel savings in the region of 20%, not to be sniffed at.
supervc-10
4 Mar 2012
A diesel-battery hybrid (IE, without a panto) could still save a bit on fuel- just like a hybrid car does compared to a regular petrol car. But the gains are minimal, and likely much less significant than with a car as the big advantage a hybrid like a Prius has over a conventional car is in stop-start traffic.
A proper bi-mode, like the 769s or the 755s, is the best idea for Northern. As long as they work.
175001
3 Feb 2007
Between Heaven and Hell
Probably due to a fault in AC mode. It's happened to me once.
This unit had issues on Saturday getting the pan up at Bolton.
It'll run OK in diesel mode all day, as long as its refuelled shortly after.
The Ham
6 Jul 2012
As above, circa 20% isn’t ‘minimal’.
Indeed and could be enough, even on moderately used services, to put DMU emissions on a par with general car emissions even when the car fleet is circa 50% of vehicles are EV's.
However certainly enough to push average rail emissions to be below EV emissions in a per person per km basis.
AM9
13 May 2014
St Albans
But even with electrification progressing at it's current snail's pace, there will be fewer and fewer trains running services that don't spend a considerable amount of their journeys under wires. So a battery-diesel hybrid (probably battery-diesel-electric), multiple unit fleet would be quite a niche requirement. The additional weight, complexity and (ultimately through-life cost) of providing for full electric running under wires or over 3rd rail would make the proposed micro-fleet(s) look not particularly cost effective and more of a green gesture designed to stave off demands for electrification extensions.
I think I’m going to disagree. There are certain fleets, with life left in them, where diesel battery hybridisation can be done relatively easily and will have good benefit. Chiltern springs to mind, some of Northern, and arguably Cross Country.
D9006
28 Aug 2019
Wigan
Thanks for the Intel on that, wasn’t sure if it was maybe policy to avoid a failure at Bolton on the late evening services changing power at Bolton
