It's not exactly the first time this has happened, I have been significantly delayed by the same stretch of overhead line at least 3 times in the last couple of years
I’m racking my brains, because I can’t remember a major OLE fault on this section (Paddington - Airport Jn) that caused all lines to be blocked. When were these other incidents, roughly?
You never hear of the GEML/WAML/LTSE wires falling, or on secondary lines further north.
Ummm…
Its unfortunate almost the same thing happened in the middle of last week on the GEML. Took out 1000m of wire, a decent number of registration arms and damaged one of the stanchions. That took 36 hours to reopen and wasn't as bad as this sounds.
I don't understand how a few miles of new electrification can be installed in an overnight possession, but repairing an existing structure takes a whole day.
a few miles of new electrification can not be installed in an overnight possession. If it was the GWML electrification would have been done in a couple of months, not 6 years.
Acton Yard had several locos stabled on it at the weekend yet the rescue locos
but no drivers…
This incident just shows how shockingly incompetent Network Rail are. I can’t believe that several miles of overhead lines would suddenly collapse with no warning, why isn’t the infrastructure being checked on a regular basis?
It is checked on a regular basis. It was fine for the dozen or so trains that preceded this one this morning.
No one has explained to me exactly why it takes so long.
In very simple terms:
1) Incident reported
2) Response teams sent to site to assess damage. If damage is bad, and includes OLE on top of and around the train, that assessment needs the train out of the way to confirm full details. That’s what happened here.
3) trains needs to be moved to platforms (if possible) and evacuated safely. About 8 in this case. Including many which could not be moved (no power…) so were evacuated to track, with passengers to be safely got off the infrastructure and on to onwards transport. This takes a couple of hours (each train needs at least three qualified people to do this).
4) trains to be recovered and got to depot, or at least out fo the way. This needs a) compatible locos and b) drivers. Several in this case.
5) Get the repair teams to Take formal control of the site.
6)start repairing the damage. A dewirement like this will need multiple teams, some working in tandem, e.g. e-erecting the same headspan wire will need two groups on separate machines. In this case there will be severla heads pans to repair, plus registration arms to re-erect (to the millimetre, in the dark) and heights and stagger checks on all four lines for over 2km when the work is complete.
7) all OLE through the affected section must be checked for further damage, including that which is not readily visible from ground level. (Numerous examples of OLE repairs completed, only for the first train to being it down again at the location of secondary damage).
8) get all the plant and personally off site
9) liven up the kit
I would love to see a single example of a TOC getting out the corporate credit card in the same way the BA have done many times for their UK domestic customers.
OK. Last year I was involved in a similar incident elsewhere on the network, and rail company Credit cards were used for taxis, hotels and coaches.
This is not remotely unusual.
