Possible electrification schemes in the pipeline?
The Class 99 has, at a stroke, removed any case for electrification of the Felixstowe and Gateway branches.
Well, if it wasn't for a lack of 750V capability I would suggest the best thing the government could spend electrification budget on would be to buy 400 of them and try to sell the freight operators on a scrappage scheme for the existing diesel fleet.
Perhaps the government can do this for the Sprinter fleet as well in favour of BEMUs?
It has made it more attractive as FOCs can say if you wire it, we can use 99s in electric mode.
I'm not sure it has.
Essentially all the benefits of electrification of the Felixstowe branch can be achieved with Class 99 purchases.
Sure they'd still burn diesel on the branch line, but that will be not be a substantial portion of the fuel burn over a full unelectrified route.
They will need diesel/big batteries for the last bit anyway because Felixstowe won't want movable conductor bar in its loading area.
4 Apr 2021
United Kingdom
Or you wire to the reception and departure sidings and have a battery loco like the 08e shunt the train around, including the electric loco. Garston has wires for the 90s, and they load containers. Having the 90s always at one end of the train allows the wires to stop short of the loading area, allowing electric freight without the need to wire the loading area at all, even with the moving OLE. The argument to convert to OLE has become even stronger as a larger fleet of electric locos could use the wires. It would also remove the time it takes to swap from a 66 to a pair of 90s.
Trainbike46
18 Sep 2021
belfast
I'm not sure I agree actually - in the long term diesel will have to go completely even from freight operations, so ideally the operations within the port would be doable on battery - and climbing the hill up to Ipswich is not ideal, so it may be worth electrifying closer to the port.
For gateway, I would suggest extending the electrification just far enough that the full train is of the mainline before electrification runs out, mostly so any issues at changeover don't affect the mainline.
But what you say applies if you don't have class 99s (or similar locos), not if you do have them.
Class15
30 Dec 2021
North London or Mildmay line
Still need at least to wire a short section of the ‘up line’ at Thames Haven Jn to allow 99s to pan up before reaching the mainline.
Also, what do you tell Freightliner with their class 90s, still being forced to change locos at Ipswich (for Felixstowe) and Wembley (for Gateway)? Suck it up?
I would do those two branches as my very first electrifications if I were in charge. Simple and short.
Only GBRf have 99s. 88s and 93s can manage Gateway but I wouldn’t trust them on the Felixstowe branch with a full container train (correct me if I’m wrong). Again, what are you saying to Freightliner, who have very commendably invested in a strong fleet of pure electric locos.
Trainbike46
18 Sep 2021
belfast
I think it is clear from the rest of my post that I'm actually in favour of electrifying those branches up to the port (but not in the port themselves)
Nicholas Lewis
9 Aug 2019
25kv electrification for freight makes a lot of sense. It can improve acceleration out of loops and from signal stops thereby gaining precious minutes for the path the train occupies. However, the really obvious quick wins of electrifying the Felixstowe and London Gateway branches have never been taken seriously by those in charge.
In BR era the Gateway branch could have been wired using simple OLE as its under 40mph which would have made it quite cost effective albeit you still have to get the train into the terminal so still need either last mile diesel/battery loco or a separate shunter which would lower economics hence you can see the advantage of the bimodes locos.
eldomtom2
6 Oct 2018
The sensible approach is surely to see what would be required to have locomotives like the Class 99 operate without using diesel on the Gateway and Felixstowe branches, and do that.
I’m sorry that logic doesn‘t follow.
Why? It’s not necessary. See Temple Hirst junction, Northallerton, Armley Junction, Cardiff, Ely, Haughley Jn and (relevantly) Ipswich. There’s many more locations where bimodes pan up on the main line.
No need to tell them anything. Why would you need to?
I’d do Didcot to Oxford, personally (other than all the electrification schemes already happening).
Class15
30 Dec 2021
It follows because, if you are doing a rolling programme, you could try and make sure the 99s are using electric on ‘core’ freight routes as much as possible.
These bimodes are passenger units though. It would make so much more sense for a 99 to be able to pan up at the signal while waiting for the mainline to become available. Can the 99s change power on the move? If they can’t then electrifying that would seem to make sense to avoid stopping on the main line for a power changeover.
If you are saying that you are not electrifying two of the most important freight routes in the country because one relevant operator (DRS and ROG don’t go to either Gateway or Felixstowe) has bi-modes, I think Freightliner would question you on why you are stopping their (recently enlarged, much to their credit) electric loco fleet from getting to these ports.
…which would be my third pick personally, behind the two ports.
AndrewE
9 Nov 2015
Would the better acceleration on electric help with train speed through the junction - a benefit on congested lines? Or is the speed through the junction likely to be so slow that how long it takes to reach it is irrelevant?
Also if failure on power change-over is at all common then it's best not done with a long freight train straddling a junction. I would say electrify the branch, even just a few hundred yards of it...
Zomboid
2 Apr 2025
Oxford
Felixstowe electrification would have the additional benefit of allowing the branch service to be run on electric power and the East Suffolk line trains could be electric to Westerfield.
How much to electrify in the ports themselves is a different question, but it should be enough to allow pure electric locos to access the reception and departure roads.
Nottingham59
10 Dec 2019
These two branches have very different constraints.
- Gateway: two tracks, level, no other traffic. So it doesn't matter how slow freights are getting from the port to the mainline. Even 88s could work the line unelectrified, let alone 93s or 99s. There's no case for electrifying the line, except at the junction when a failure to pan up won't block the mainline.
- Felixstowe: single track, substantial hill, hourly passenger service. The timetable is massively constrained by the time it takes 66s to get up the hill and interwork with passenger trains. 99s would take just as long or even a bit longer; 93s cannot work the availalbe timetable slots without wires. I think there's a really strong case for electrification if you want to increase the capacity for freight traffic out of Felixstowe.
WAO
10 Mar 2019
The logic of electrification is that the marginal cost of electric train miles is much lower than the marginal cost of Diesel train miles (and even battery train miles, according to Wiki). The proof is bi-mode operation as they would work pan down if equal peformance could be obtained more cheaply. However, one needs a lot of train miles to justify the extra infrastructure.
The MML certainly up to the E Mids looks busy enough; the 1931 report proposed 2.3M x(train)x ton miles per year as the then starting point; about 180 mark 1's per day, perhaps 22 eight car workings, which might include the line as far as Sheffield. The MML also had the best prospects in the 2009 review. Short, infrequent trains, low speeds and continuing Diesel working indicate against electrification but battery/bi-mode working is clearly better than persisting with Diesels and also for short branches and "last mile".
Horses for courses.
WAO
Electrodiesels mean that electrification should be installed on those sections of track where it reduces diesel burn by the most per unit cost.
A short single track freight dominated branch is probably not going to score particularly well on that score.
Single track railways have relatively low utilisation and small projects will be more expensive per kilometre due to mobilisation costs.
(EDIT: I make it only 27 actual round trips by freight trains on the branch on Friday 4/07/25)
"Because we don't have a business case to spend that much money for so little benefit" would probably be a pretty potent answer in this context.
Freightliner pays almost nothing for the infrastructure, electrifying for the benefit of their 35+ year old electrics is going to have a terrible return on investment.
Brubulus
13 Oct 2022
Cambridge
I would agree that there is no case for electrifying London Gateway, however there is clearly a case for electrifying Felixstowe, given it enables electric locomotives with small batteries to operate there, and the substantial performance benefits.
Yes but enabling FOCs to use electric traction should enable more paths across the wider railway. The cost of slow freight paths likely makes the abstraction caused by OA look trivial.
You won't get much electrification for the cost of simply giving everyone Class 99s to replace the remaining Class 86s, 87s and 90s in use.
Did you mean to put this? Neither of these locos have worked freight trains recently, and for the 87s it’s been about 20 years! (I think)
I didn't think they had been, but I am not necessarily up to date, so I thought I would hedge!
I didn't include Class 92 because they have a capability that Class 99s lack that could be useful later (750V operation).
eldomtom2
6 Oct 2018
the 1931 report proposed 2.3M train miles per year as the then starting point; about 180 mark 1's per day, perhaps 22 eight car workings, which might include the line as far as Sheffield.
Surely train miles aren't affected by number of carriages?
Bristol
The issue here is that it's fairly useless to get 90s only to the port gates. Electrified freight terminals are possible but an operational minefield, and Felixstowe is extremely busy so complicating operations is not advisable.
Felixstowe and London Gateway are useful, but Lawlery St is also not far from an electrified mainline and electrifying Nuneaton to New Street would potentially allow more WCML trains to go over to electric traction if last miles can be covered by some means.
Class15
30 Dec 2021
Felixstowe has shunters available and at London Gateway you can do the Garston/Trafford Park/Coatbridge method of running round and shunting the wagons into the terminal while the locos remain under the wires.
Lawley Street appears to have 3 trains a day that could go over to electric traction for most of the route but would still require last mile (2 London Gateway, 1 Felixstowe) while London Gateway appears to have 4 a day to fully electrified destinations (3 Trafford, 1 Garston, 1 Coatbridge) that could go over to 90s tomorrow, and 8 more to ‘last mile off-wire’ destinations (2 Ditton, 2 Lawley St, 2 Hams Hall, 1 Birch Coppice, 1 Wentloog). Probably more if Doncaster/Leeds workings took the ECML instead of the ‘joint’ line.
Services that could be fully electric: London Gateway 4, Lawley St 0
Services that could be electric until the ‘last mile’: London Gateway 8, Lawley St 3
Plus Nuneaton to Lawley Street (or New Street) is far longer than Thames Haven Jn to London Gateway.
I think that Lawley St probably should be done, but Gateway is higher priority, surely.
Bristol
So complicating operations?
Gateway only benefits gateway whereas Nuneaton to New Street gives much wider network benefits, especially in the context of the upcoming Midlands Rail Hub Plans.
You can get all of the benefit of Thames gateway with a last mile loco, which isn't the case with Nuneaton to New St (especially as there's an obvious follow on of Nuneaton to Wigton).
Class15
30 Dec 2021
A very minor consideration compared to a train running 200 miles running on electric instead of diesel.
All trains on the Birmingham to Nuneaton currently go on to at least Leicester.
A last mile loco that is likely to be unaffordable in large numbers. There are several Freightliner trains that can go over to Class 90 haulage tomorrow with Gateway electrification.
We can get 200 miles on electric instead of diesel by simply buying the Class 99 instead though.
The electrification of Gateway and Felixstowe would likely cost enough that the Government could just give freightliner Class 99s one for one for the Class 90s and come out ahead though.
Gateway especially will be a mess because mobilisation costs will dominate and its cost per kilometre will be enormous. Five or six track kilometres that could easily end up costing tens of millions of pounds.
AndrewE
9 Nov 2015
Why? Google Earth https://www.google.com/maps/search/...try=ttu&g_ep=EgoyMDI1MDYzMC4wIKXMDSoASAFQAw== seems to show loads of undeveloped land around Gateway for a worksite, including a big triangular "field" at the west end off the main road roundabout. Plus you could always move stuff in by rail (or water). Some of the land might have already been developed, of course, but there is also a triangular fan that looks like ex rail sidings at the east end too.
Why? Google Earth https://www.google.com/maps/search/london+gateway+port/@51.5079768,0.4697853,1067m/data=!3m1!1e3!5m1!1e1?entry=ttu&g_ep=EgoyMDI1MDYzMC4wIKXMDSoASAFQAw== seems to show loads of undeveloped land around Gateway for a worksite, including a big triangular "field" at the west end off the main road roundabout. Plus you could always move stuff in by rail (or water). Some of the land might have already been developed, of course, but there is also a triangular fan that looks like ex rail sidings at the east end too.
Well you have a lot of costs in setting up a project team, acquiring site compounds and all that, but with very few kilometres of electrification to amortise these costs over.
AndrewE
9 Nov 2015
Let one contract for Gateway and Felixtowe together then, to be done in succession with a compulsory holiday in between while the site huts are moved to the other half of the job.
