Potential future uses for class 68 & Mk5 sets?
1 Feb 2018
There is no first class or 'business zone'. Its been declassified for many years.
Indeed. People seem to be forgetting that Chiltern is closer to LNWR than it is to Avanti.
Chiltern would be taking the mk5As because it desperately needs more stock, and its preferred partial electrification is years off. I wouldn't assume that the mk5As will live out the rest of their life at Chiltern.
Indeed, Chiltern is rarely more than 7/8 cars.
The mk5A sets also need to meet 168 timings, which isn't happening with 8+ cars.
Please correct me if I am wrong, but i am pretty sure current 68 and mk3 rakes actually have better performance than cl168. 168s are quite sluggish off the mark despite a more even traction distribution compared to a 68 which will fly with off with load 7
Energy
29 Dec 2018
A quick look on RTT and you're correct, 68 sets tend to be slightly faster.
craigybagel
25 Oct 2012
IIRC, when Chiltern switched from 67 to 68 it was stated at the time they could add an extra carriage and keep to the same timings, if they had so chosen.
GusB
Elginshire
Could you sandwich a class 68 in the middle of 2 Mark 5 sets (at the point where there is currently no corridor connection) - both in terms of power and control systems?
Placing a loco inbetween two sets of carriages is done on the continent, so it's technically possible to do. Whether or not the Class 68s are equipped for it, I do not know. Nor do I see the point!
Would be pointless. Anyway the power required might mean two 68s required so ideally one at each end, otherwise one at one end.
68s fall within the Type 5 bracket, do they not? I'm fairly sure they'd be able to shove/haul 10 carriages.
Harpo
21 Aug 2024
Newport
It’s always happened here too if you think about an EMU’s motor coach as its loco, plus many UK examples of mid-formation steam diesel and electric locos.
The mk5/68/mk5 question is whether that formation would actually work without major & expensive mods, and ‘why’.
BlueLeanie
21 Jul 2023
Haddenham
Technically shouldn't a multiple working system be designed to operate with multiple desks? So a 68-68-Mk5 shouldn't be any different from a Mk5-68-Mk5.
I'd love to see one in action all the same.
Bikeman78
26 Apr 2018
The Belgians seem to come up with all sorts of weird formations. It's possible to see four types of stock in a hauled formation. Any driving trailer seems to work with any loco and any stock in between.
But I agree with the view that putting the 68 in the middle would be pointless. If a set has a driving trailer on both ends, attach the loco to one end and plug in the usual cables. That would work wouldn't it?
Peter Sarf
Croydon
It will depend on how much acceleration you want. Modern era is tighter timings than a limited stop Deltic + 8coaches was.
ry34081
20 Nov 2009
Kidderminster
Word is it will be 10 sets, 3 as spare maintenance. Aditional coaches may be added at a later date? It is clearly enough to do all Bham /Lon services. Should free up stock to strengthen others and reintroduce Ban/London service.
From other forum
"SPC7/8
LN3201
London Road Jn - Derby Station
Details of Network and associated works required to facilitate Vehicle Change
The MkSa coaches are fitted with Automatic Selective Door Operation (ASDO) equipment. This requires the installation of track beacons at some platforms between London Marylebone and Banbury, Chiltem Railways will engage with Network Rail to seek a Network Change for their installation.
"Proposed timescales
The current proposed timescales are:
Chiltern Railways seeks to commence driver training from May 2025.
4 x trainsets in passenger service by March 2026.
9 or 10 x trainsets in passenger service by December 2026.
Costs and compensation
Costs and compensation as per Network Code.
Additional terms and conditions
None"
From other forum
"SPC7/8
LN3201
None"
What Network Change is that from? Not seen anything proposed by Chiltern yet.
Zomboid
2 Apr 2025
Oxford
Didn't they design the Mk5 DTs to have a similar cab to a 68? Should accelerate driver training if they did.
9 Dec 2023
High Wycombe
Being reported in RAIL that the 13 five car sets is likely to happen as mentioned above by ry34081.
Timescales seem quite generous to me - not exactly close to “the first set is expected around April 25 for testing and training” as was said back in the autumn
Would that result in the busiest trains having to be multiple 168s, and the 68+Mk5s bring used on less busy services?
It seems a shame that a 68+Mk5 can't tow / propel a 2-car 168 about.
9 Dec 2023
High Wycombe
The 168s would be freed up to run more services - shift some of the stops onto a 168 MYB - BAN and that relieves some of the pressure. I’ve been designing my own “what if”Chiltern timetable based on Mk5s happening and this is what I went for. (That and ordering extra coaches to go behind the current 68s to bolster the fleet to 19 and facilitate services to Worcester and extra peak services)
stevieinselby
6 Jan 2013
Selby
In the morning peak, it shouldn't be too much of an issue, as the 6-car sets alternate with 4-car formations, so replacing them all with 5s would lead to a similar number of seats across the period – it's only in the evening where it tends to go 4-6-5-6-4 that you have 3 trains in a row that are longer than 4 and so you could see a reduction in capacity. But if that full capacity is needed then it may be better served by using released 168s to run a short working to maybe Bicester or Banbury, allowing the Birmingham trains to skip some intermediate stations.
Zomboid
2 Apr 2025
Oxford
How many trains are there where 5 cars isn't enough? I'd imagine some peak time workings into and out of Marylebone might be a bit cosy, but 6 cars seems to be the biggest trains that regularly run anyway.
craigybagel
25 Oct 2012
A surprisingly small portion of the time spent on traction training for drivers is spent on cab layouts - or even practical handling. It's mostly on understanding how it all works, that's likely to be quite different between MKIIIs and MKVs.
Reseat First to Standard and densify Standard a bit (it's almost all facing seats in a very low density layout at present) and you'd get the number of seats to similar to a Mk3 formation.
9 Dec 2023
High Wycombe
I feel like keeping first to reintroduce some kind of more premium zone like business zone or first class or whatever is definitely a good idea. Gives it more of an intercity feel, which a journey of that length needs. Talking of which, they should bring back the trolley service too IMO.
As demand increases you can always order more coaches from CAF
Bevan Price
22 Apr 2010
Something similar happened in UK at the start of London - Bournemouth electrification. Not all the emus had been delivered, so some trains ran as 4TC-73-73-4TC formation.
AJDesiro
10 May 2019
Rugby
It wouldn’t go down well if a train company introduced first class causing a decrease in standard class seats…
What needs to happen is the Mk5as gaining a more high density layout as @Bletchleyite stated, otherwise the reduction in capacity would be incredibly apprarent. Something like the seating layout that the 80x have would work well.
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
Usually ran as pair of 73s at one end. It was like that every time I saw it.
43096
23 Nov 2015
It would be good if they could get rid of the Fainsa junk seats while they are at it and put something better in.
9 Dec 2023
High Wycombe
On another note, I wonder what livery we’re gonna get? Is it likely to be based on the current silver set livery or more like the new 168 one? Or maybe something completely different of course!
It would, but I can't see them being willing to spend the money.
GBR livery by the time they finish faffing?
SeanG
4 May 2013
The mk5as have a base of grey livery. Just sticker that up. No need to spend money unnecessarily on liveries when every penny counts. I'm sure that the travelling public would rather have a train in the "wrong" livery than a delayed introduction due to applying a livery (that's if they even notice or care)
