mcnw35282
I heard somewhere the Wigan platform at Headbolt Lane has been designed to be less substantial than the two Liverpool ones to make it easily removable should extension to Skem or Wigan be approved in the future.
I was hoping it would be so, the 777s are known to be capable to get to Wigan and back, and there's a platform at Wigan that fits a single 777. P3 rarely sees use. (not fit doubles but I wouldn't be annoyed if they stripped out the gardens to extend it).I heard somewhere the Wigan platform at Headbolt Lane has been designed to be less substantial than the two Liverpool ones to make it easily removable should extension to Skem or Wigan be approved in the future.
I thought the plan was for Merseyrail and Manchester trains to go to Skelmersdale?I was hoping it would be so, the 777s are known to be capable to get to Wigan and back, and there's a platform at Wigan that fits a single 777. P3 rarely sees use. (not fit doubles but I wouldn't be annoyed if they stripped out the gardens to extend it).
Not preparing Headbolt Lane for an extension would make an extension harder to approve and less likely to happen.
That plan was scrapped when the inevitable u-turn on providing funding for “levelling up” happened. The people of Skem were told to get a bus instead.I thought the plan was for Merseyrail and Manchester trains to go to Skelmersdale?
That's their fault for voting Labour!That plan was scrapped when the inevitable u-turn on providing funding for “levelling up” happened. The people of Skem were told to get a bus instead.
I don't think the government had ever suggested Skem would be funded. As far as I know it was never more than a hope by the local authorities that funds might be found. The idea of the branch to Skem has been around since long before levelling up became a Johnson catchphrase.That plan was scrapped when the inevitable u-turn on providing funding for “levelling up” happened. The people of Skem were told to get a bus instead.
Rainford Jct is quite awkward for buses from Skelmersdale though. You could go via Crawford village, which has the advantage of passing Upholland Station and Pimbo Garden Centre, but is quite a winding route. Or you could go direct via Nipe Lane, but that's a single track road which even cars barely manage to get down. That leaves going along the Rainford By-Pass, which is 15 minutes according to "Bing Maps" (assuming you avoid the motorway as you'd expect a service bus to do) and passes literally nothing between leaving Skelmersdale and reaching the station.The bus seems to pass achingly close to Maghull North on it's way between Skelmersdale and Kirkby, however justifying a call at Maghull en route seems a bit pointless given it goes to both Kirkby railway AND bus station for onward connections.
I'll add driving times for Merseyrail stations near to Skelmersdale for information (From Concourse):
Kirkby - 14 minutes
Ormskirk - 13 minutes
Aughton Park - 14 minutes
Town Green - 15 minutes
Maghull North - 12 minutes
Old Roan - 14 minutes
*Rainford - 8 minutes
*Upholland - 7 minutes
*Headbolt Lane - 14 minutes
*Might be worth considering bus links to here in the near future.
The current service already uses the M58, they're trying to connect the two fast.(assuming you avoid the motorway as you'd expect a service bus to do)
Until Merseyrail run services there, it's not, that line gets 1 train each way an hour, only to either Kirkby [future Headbolt Ln] or Blackburn via Wigan, Atherton, Manchester and Todmorden.Upholland station would be the best railhead for Skem
If Merseyrail is extended towards Wigan, I believe there will have to be a single track section just east of Headbolt Lane. For about 600m the existing single track runs alongside the Arrival & Departure siding of the Knowsley freight terminal. I doubt that the formation is wide enough for a third track here (the siding is gated and fenced off from the main line).Correct. If/when the line extends through, that platform will be demolished and a footbridge with lifts will be installed, making it a standard two-side-platforms station like the thousands of others around the UK.
It's a bit offset because of the shape of the plot, I believe.
at least Headbolt Lane will have two permanent platforms making it a good passing place.If Merseyrail is extended towards Wigan, I believe there will have to be a single track section just east of Headbolt Lane. For about 600m the existing single track runs alongside the Arrival & Departure siding of the Knowsley freight terminal. I doubt that the formation is wide enough for a third track here (the siding is gated and fenced off from the main line).
What is the current state of play with regards to that particular matter, in any official statement made?If Merseyrail is extended towards Wigan.....
The plan for the Skem extension would have been a single line all the way from Kirkby to Skem, with a bay platform at the end of another single line at Headbolt Lane for the Merseyrail services that are terminating/starting from Headbolt Lane towards Liverpool. The Wigan side would also have been single line to Skem. Confusing to say the least, but probably the cheapest and most operationally isolated/convenient way to do it.If Merseyrail is extended towards Wigan, I believe there will have to be a single track section just east of Headbolt Lane. For about 600m the existing single track runs alongside the Arrival & Departure siding of the Knowsley freight terminal. I doubt that the formation is wide enough for a third track here (the siding is gated and fenced off from the main line).
There's already a single line segment that ends in the current Kirkby platform (talking about Liverpool side), if the line was made continuous Headbolt Lane could easily become a passing point already, so there's probably be enough time to get to Rainford in that gap.though without double tracking it to Rainford it would limit the frequency.
That’s only if they connect the two Merseyrail lines at Headbolt Lane. That wasn’t in the plan for Skem but could probably be done without too much effort.There's already a single line segment that ends in the current Kirkby platform (talking about Liverpool side), if the line was made continuous Headbolt Lane could easily become a passing point already, so there's probably be enough time to get to Rainford in that gap.
Isn't connecting the two lines the whole reason the Northern platform is able to be disassembled much easier than the merseyrail ones (post #183)That’s only if they connect the two Merseyrail lines at Headbolt Lane. That wasn’t in the plan for Skem but could probably be done without too much effort.
I think to allow for freight paths to/from Knowsley, Dale Lane to Rainford would need to be redoubled. Although it could possibly be configured as parallel single lines (Merseyrail and freight)....though without double tracking it to Rainford it would limit the frequency.
The plan for Skem was for a new branch line to leave the L&Y main line at a triangular junction between Rainford and Upholland. Whether this was to be configured as parallel single tracks Kirkby - Skem and Skem - Wigan, double track left hand running throughout or single track only I don’t know, but it is quite fortunate that freight access to Knowsley means the line between Rainford and Upholland cannot be severed, which improves the case for conventional double track running, whether to Skem or only to Wigan.The plan for the Skem extension would have been a single line all the way from Kirkby to Skem, with a bay platform at the end of another single line at Headbolt Lane for the Merseyrail services that are terminating/starting from Headbolt Lane towards Liverpool. The Wigan side would also have been single line to Skem. Confusing to say the least, but probably the cheapest and most operationally isolated/convenient way to do it.
How many trains make use of the terminal on a daily basis? From RTT it looks like maybe two in and out. If they did want to double-track throughout, what's the feasibility of adding the necessary S&C to make the existing track bidirectional and join the siding at the other end so that it can be used as both a through track and as a reception road?If Merseyrail is extended towards Wigan, I believe there will have to be a single track section just east of Headbolt Lane. For about 600m the existing single track runs alongside the Arrival & Departure siding of the Knowsley freight terminal. I doubt that the formation is wide enough for a third track here (the siding is gated and fenced off from the main line).
I am sure such S&C would be technically feasible. The question is how much Merseytravel would be willing/able to spend on resignalling, for an extension from Headbolt Lane to Wigan. Currently the single line from Rainford to Kirkby is token operated from the Rainford box, with a token machine at the Dale Lane ground frame that enables a freight to be locked in the freight terminal while passenger trains use the line. The double track line between Rainford and Wigan Wallgate Junction is Absolute Block.How many trains make use of the terminal on a daily basis? From RTT it looks like maybe two in and out. If they did want to double-track throughout, what's the feasibility of adding the necessary S&C to make the existing track bidirectional and join the siding at the other end so that it can be used as both a through track and as a reception road?
An advantage of Headbolt Lane as the Merseyrail terminus is that it preserves the segregation between Merseyrail and freight services, avoiding the risk of importing delays into the Merseyrail network.
There is currently 4tph from Wigan Wallgate towards Manchester, two via Bolton, two Via Atherton,by selecting the right 2tph services to continue past Headbolt Lane to line up with the Southports for the Manchester connection
When was the first time that the introduction of a third rail system into Wigan Wallgate was discussed in council meetings of Wigan and has the council expressed any current views on the matter?I am sure such S&C would be technically feasible. The question is how much Merseytravel would be willing/able to spend on resignalling, for an extension from Headbolt Lane to Wigan.
The first mention by the Wigan Corporation of extending the third rail electrification of the Lancashire and Yorkshire Railway from Southport to Wigan was probably made before the First World War!When was the first time that the introduction of a third rail system into Wigan Wallgate was discussed in council meetings of Wigan and has the council expressed any current views on the matter?
However are some of these going to be diverted to North Western, due to the overhead electrification from Bolton not going to Wallgate?There is currently 4tph from Wigan Wallgate towards Manchester, two via Bolton, two Via Atherton,
currently at 07 (from Southport), 20 (currently from Kirkby), 39 (from Southport), 49 (starting there)
past each hour, and take basically the same amount of time, times like that make connections pretty good already.
yes by the maps I have the overhead only goes into Northwestern (getting it under Wallgate would/will be a massive challenge)However are some of these going to be diverted to North Western, due to the overhead electrification from Bolton not going to Wallgate?
To develop this idea further a Skem railhead could be created by replacing the existing Upholland station with one a little nearer Liverpool and making that the termination point for Liverpool and Manchester services. There is room there for a decent sized car park and being so much nearer Skem could make the provision of connecting bus services much cheaper allowing them to operate at better frequencies than the half-hourly interval of the new 329 service. I also suspect that having such a railhead so much closer to Skem than Maghull would make it much more attractive. The problem with Maghull as a railhead is to reach it from Skem you drive along the M58: once on the motorway I suspect many people would prefer to simply continue driving all the way to Liverpool.Upholland station would be the best railhead for Skem, but the main access is on Pimbo lane, which is a narrow small road with no parking and which has deliberately been isolated from the Skelmersdale road network and a nearby industrial estate. For a fraction of the cost of building Skelmersdale station, it could be possible to open out a bigger access and add car parking in the industrial estate. That would be just under 3 miles away from the Concourse and a 5 minute car journey.
