Printable timeables with every station and stock used?
sn1975
16 May 2011
Hi all,
Is there a printable timetable site that shows every station called at during the journey (including previous stations) and the rolling stock normally used?
Many thanks.
7 Nov 2009
Newcastle
East Coast also do the same but very uncommon to do so across other TOCs.
trc666
6 Jul 2005
Islington
East Coast also used to include the headcodes (1S07, 1D05 etc) in their timetables, as did National Express and previously GNER.
Muzer
3 Feb 2012
You could always print off pages from Open Train Times (the advanced mode shows what type of train the services are booked for).
Where? Am I missing something? I'm in advanced mode, I can see everything else, but can't see the train type... I must be blind ;)
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Under Details, where it says "timed as...". It won't give you the exact class number, just the type of train (which you have to get used to, for instance DMUA means a Pacer, DMUS is a Sprinter (you can work out which from the speed), I think Turbostars are DMUE, EMU375 could be any Electrostar...)
Muzer
3 Feb 2012
Oh, I see - heh, I expected to see a class number somewhere. Never mind!
TEW
16 May 2008
FGW mark which trains are HSTs in their timetables with a little H above the service. Adelantes used to have a little A, so hopefully when they return it will be indicated which services are booked for 180s as well.
Eagle
20 Feb 2011
They also mark Voyagers too, with a V, on timetables where XC services appear.
EC timetables also distinguish between their two types of train. EMT mainline timetables do too. Other timetables give clues (for instance you can spot 442s on Southern and GX services because they are listed as having restricted wheelchair access).
DAH
17 Apr 2008
Hi all,
Many thanks.
Just this morning I have updated Headcodes to include the option of getting your hands on a PDF of your selected train or full station timetable for the given day.
As of yet, the traction type is not listed on the PDF's but will be working on a script to show the traction as class type rather than DMUA, DMUX E 410 etc, this is quite a tricky job, but Im working on it
