You have to set up fares using the OSI and maintain them at every fares change.how much does it cost to add an OSI? Surely there is a small set-up cost and no ongoing cost, so the "worth it" comment isn't really relevant?
If the fares exist for paper tickets in the current setup, aren't we already doing that anyway?You have to set up fares using the OSI and maintain them at every fares change.
The two fares databases are not linked, as far as I know, so there is an extra step to maintain the PAYG fares. I'm not fully aware of all the processes involved, but some of the fares set up on the early Oval implimentations prove that knowledge of how the PAYG system works is not fully understood.If the fares exist for paper tickets in the current setup, aren't we already doing that anyway?
it seems counterintuitive to offer through pricing on paper tickets but not Oval?
The previous discussion (in February) was that it hadn't been, even though a small number of fares suggest that one was envisaged.With the extension of contactless to both Windsor stations (Central and Riverside), has an OSI been set up between them?
There are currently no OSIs outside London. Anyone doing Datchet to Slough via Windsor will be charged for two journeys. Anyone doing it via London will be charged the fare that Single Fare Finder shows...
From a Slough office, I recall quite a movement of our staff between the two Windsor stations, Slough to Richmond etc being difficult otherwise. One was daily Slough to Whitton. Some I think used to do their grocery shopping on the evening walk between the two. Of course, being two different TOCs, there is probably no data of how many.With the extension of contactless to both Windsor stations (Central and Riverside), has an OSI been set up between them? Should it be? Is it planned? As National Rail Enquiries will give through journey times and (non contactless) fares by this route (e.g. Staines to Slough), I would say it should...
Are there any other such situations, where OSIs should be set up within the 'Project Oval' area (outside the zones)? (St Albans and Southend are two that come to mind as possibles)
Um ... isn't that what the revenue management teams do for a living ...?The two fares databases are not linked, as far as I know, so there is an extra step to maintain the PAYG fares. I'm not fully aware of all the processes involved, but some of the fares set up on the early Oval implimentations prove that knowledge of how the PAYG system works is not fully understood.
There are fairly large flows between the two Windsor stations, particularly to/from Staines and on rugby days.From a Slough office, I recall quite a movement of our staff between the two Windsor stations, Slough to Richmond etc being difficult otherwise. One was daily Slough to Whitton. Some I think used to do their grocery shopping on the evening walk between the two. Of course, being two different TOCs, there is probably no data of how many.
Not impossible if you go via Ealing, or if the barriers are open at Riverside.they show in NRE but in reality it’s impossible to pay that price
Can you give me an example of a station pair that this applies to?There are also GWR-priced contactless fares
Slough to Datchet is still priced as if there were a Windsor OSI, although 3 hours appears to be allowed for the journey.Can you give me an example of a station pair that this applies to?
Definitely agree with this. Even in the zones it an annoyance buying a paper ticket in the evening but tapping in the morning.The big problem that undermines support for this extension of contactless is the TfL afternoon peak. TfL need to get rid of the afternoon peak. It complicates fares and clashes with mainline rail fares including SWR that only have a morning peak. Rail passengers do not want an afternoon peak to be imposed where it does not currently exist. It would even be better to raise off peak fares slightly if necessary to make removing the afternoon peak revenue neutral instead of continuing with this afternoon peak that complicates fares.
What rail passengers want and what is imposed on them are different things. There are winners and losers in any kind of fares reform.Rail passengers do not want an afternoon peak to be imposed where it does not currently exist.
That is effectively what the off-peak zone 1 centric cap does, but it isn't much use for journeys that don't reach central London. For example, according to the Oyster fares site, Reading to London is £30.40 peak, £14.00 off-peak, but the off-peak cap is £34.40 (should this be £35.40 in line with the increased one day travelcard?), so the return peak journey should 'only' be £20.40, not £30.40.It would even be better to raise off peak fares slightly if necessary to make removing the afternoon peak revenue neutral instead of continuing with this afternoon peak that complicates fares.
I assume part of the issue is the fact that currently the single fare for most routes is not half the return, so most people commuting into London will buy an anytime (peak) return ticket, because they need to arrive into London before 9.30am. Its not possible or cheaper for many routes to get peak single in the morning and off-peak single in the evening on paper tickets. But once the ticket price is half the return price, it may be cheaper to get peak single in the morning and off-peak in the evening rather than an anytime return. The train is still full of commuters at 5.30-6pm and busy.The big problem that undermines support for this extension of contactless is the TfL afternoon peak. TfL need to get rid of the afternoon peak. It complicates fares and clashes with mainline rail fares including SWR that only have a morning peak. Rail passengers do not want an afternoon peak to be imposed where it does not currently exist. It would even be better to raise off peak fares slightly if necessary to make removing the afternoon peak revenue neutral instead of continuing with this afternoon peak that complicates fares.
Wonderful. https://assets.nationalrail.co.uk/e..._as_you_go_with_contactless_caps_Mar_2025.pdf still says the price quoted on my site. I'll look into updating shortly.The Oyster fares site is then out of date compared to the latest caps at https://tfl.gov.uk/fares/find-fares/national-rail-fares-beyond-zone-9 which show an off peak daily cap of 35.40
Presumably this also applies to all the stations between Reading and Iver (plus the branches) where GWR are the fare setter following the fare change on 8th June.The Oyster fares site is then out of date compared to the latest caps at https://tfl.gov.uk/fares/find-fares/national-rail-fares-beyond-zone-9 which show an off peak daily cap of 35.40
We advise customers travelling from stations east of Upminster and Grays to Fenchurch Street and Liverpool Street to purchase paper or mobile tickets today to ensure you pay the correct fare. A technical issue in our fares data means pay as you go with contactless fares are currently being charged at an additional £3 for these journeys. All other journeys, including those onwards using the Underground, are unaffected. We are working with TfL to resolve the issue and will be issuing guidance soon on how to claim for a refund.
This only applies to journeys that either started or ended at Fenchurch Street or Liverpool Street stations.
c2c would like to apologise to customers for any inconvenience this technical issue is causing. Customers are advised to keep a full record of all contactless journeys where they have been overcharged, and a further update, including details of how to claim a refund, will be shared as soon as possible.
We advise customers .……… to purchase paper or mobile tickets today to ensure you pay the correct fare.
And people are still saying contactless should be rolled out across the whole country !! If people making a straightforward journey on a self contained route can be overcharged by more than 30%, imagine how much you could be overcharged on a longer, more complicated journey.Customers are advised to keep a full record of all contactless journeys where they have been overcharged, and a further update, including details of how to claim a refund, will be shared as soon as possible
Isn't it TfL who do the charging for contactless?then c2c are charging 10p more in the peak to use the Underground in zone 1 than splitting the journey in two.
On the instruction of the train companies, yes.Isn't it TfL who do the charging for contactless?
That doesn't automatically mean that it c2c at fault.On the instruction of the train companies, yes.
To quote from the BBC News page at https://www.bbc.co.uk/news/articles/cx2jzx3l8zwo ,That doesn't automatically mean that it c2c at fault.
TfL said: "We are aware that, following a pre-planned update to the fares data within the contactless pay as you go system last weekend, some of the data provided by c2c was incorrect."
It confirmed contactless fares on other routes were unaffected.
With Oval fares it does I'm afraid. TOCs provide the data which Cubic add to the CPAY database.That doesn't automatically mean that it c2c at fault.
There is no afternoon peak on the SWR network.For most commuter routes it makes sense to have the afternoon peak and it does effectively currently exist due to the need to buy an anytime return in the morning.
I doubt if it will be rolled out over any more of the SWR network. There is no sign of this happening at present. The rollout over the SWR network has been very limited, keeping almost entirely within the boundaries of Greater London. I cannot see anyone pushing for any extension to more of the SWR network if it means complicating ticketing by adding an afternoon peak at more stations.There will be when Oval rolls out. It is standard TfL times across the area.
They could opt not to standardise the paper fares with the Oval ones, but that would be a strange move as it would make using contactless in the evening undesirable.
