Publication of Integrated Rail Plan for the North and Midlands
MattRat
26 May 2021
Off the top of my head, it'll come up around where the Olympic Freight Terminal is, pass over the line to Hadfield and Stalybridge, threading it's way between Ardwick station and depot, before landing at a similar height to the Trainshed.
I don't get this obsession/problem over it being on stilts. Doesn't seem to be an issue with the already existing infrastructure, so why now?
It's cleary a problem to the residents who will live by it. Probably will lower property value too, which is not what you want in a city supposed to benefit from the project. Also it can't be easily claimed to be a necessary cost cut when you look at the no expense spared phase 1 part of the route, and even if that wasn't the case, it would be better to build a station further from the centre connected to one of the Metrolink stops which would be even cheaper and not cause problems for residents.
Ianno87
3 May 2015
Residents? Do you even know the area? It's basically all low-rise light industrial type-properties at the moment.
And anyone moving there to new developments after the railway has been built will know full well there's a railway there.
This is absolutely the case, the route inside the M25 is almost entirely tunnelled, there is a 10 mile tunnel through the Chilterns, but if Liverpool wants a captive HS2 station, which would require 2-3 miles of tunnel, or Manchester wants a through station and NPR tunnel out to the east that costs too much. In London and the South East no cost was spared, in the North people are expected to get by with reused existing lines and an urban viaduct.
If Liverpool wants a captive HS2 station, that means a lot of land take and tunnelling. At an educated guess, £5bn+. To save a couple of minutes.
Didn’t the chiltern tunnel only get added in at great cost after locals kicked up a fuss about visual intrusion on the countryside? Maybe they should have just stuck them all on a train up to the dales or Lake District to show them what proper scenic countryside looks like.
The London tunnel from Old Oak to Ruislip was added, whilst the Chiltern tunnel was extended 2.6km to finish at Gt Missenden.
And where was that £38bn spent? (or not?) 4 projects in Greater London...
Five of them are in London, and all got completed. Fairly arguable that only one of them is entirely *for* London, but the others certainly lean pretty strongly towards being *for* London and the south-east. The two in the north of course just casually haven't happened.
The last two are one signalling renewal project. If you include them you should include all the others, including New Street Resignalling, Bristol East, etc.
How many miles, how long will it take and...how much will it cost (eventually)??
Approximately 7.93491 miles
It’s pretty obvious where it will go - there’s a reason HS2 enters a tunnel at Ardwick depot. Why would the new line to Yorkshire do anything other than enter tunnel there too?
The issue with tunnelling all the way is going to be the nature of the geology and also locating the necessary evacuation shafts. At a guess I expect it will have to ‘come up for air’ at least once.
MattRat
26 May 2021
Sorry, I forget sometimes the 'news' can be misleading. I'll take your word for it since I presume you live there. You didn't counter my cost argument though. It's cheaper to build away from the city centre and connect to a tram stop at the end of it's line than it will ever be to build in the city centre.
Ianno87
3 May 2015
Not sure about that - the proposed HS2 site is pretty much outside the core of the built up city centre. Like I say, mainly light industrial type stuff that easy to move, plus some semi-derelict land.
Suggest the bigger challenge will be the interaction with some of the main roads in the area (e.g. the end of Mancunian Way, where it meets Great Ancoats Street).
For the avoidance of doubt, below is the proposed HS2 route out of the new station adjacent to Piccadilly ( as published on the Government website). Immediately after crossing the A665 the route falls at 2.5% (1:40) and enters tunnel in the Ardwick depot area. I can’t see how the NPR line could be any different.
Is tunnelling in central Liverpool a problem?
I have read in several places that a wealthy Victorian Liverpudlian build a few miles of tunnel plus caverns under the city just as a hobby.
Electric train tunnels don’t have any land take once they are built.
Of course it isn’t.
Building an underground box straight and level long enough to accommodate 400m trains and wide enough for, say, 4 platforms, below sea level, certainly is though. Doable, but very, very expensive.
tomuk
15 May 2010
You don't seem to grasp the size of the issue, HS2 will deliver 3 x 400m trains each hour purely from London, not to mention the services from Birmingham or the NPR services too, that's way too many passengers to dump at Wythenshaw tram stop and let people use Metrolink to complete the journey.
Worth pointing out that with electrification of MML, Transpennine, and of course HS2, the electrification market is going to be running pretty hot for the next 7-8 years.
MattRat
26 May 2021
How is Piccadilly not in the core of the city? Unless I'm dumb and the actual plan is elsewhere.
Ianno87
3 May 2015
Because Piccadilly is actually on the edge of the core of the city. The area just to the east of the present station / approach tracks is very much not "city centre" - which is why the HS2 station is planned to go there as developable space.
tomuk
15 May 2010
Of course it isn’t.
This is the current Piccadilly HS2/NPR proposal six platforms and the NPR junction at Tonge St just West of Ardwick Depot.
LOL The Irony
29 Jul 2017
Chinatown, New York
All @MattRat needed to do was look at google maps to see this was the case.
Of course it'd be cheaper to dump it in an industrial wasteland and tram everyone in, but that won't be the best use of money for the project. Firstly, you'd have the problem of connecting passengers wanting onwards destinations like Salford and Bolton are dumped miles away from where they want to be (ie: Piccadilly, Castlefield or Victoria).
You have an out of date map there, here's the new alignment
tomuk
15 May 2010
No you have the out of date map the tunnel portal is between Midland Street and Rondin Road next to Ardwick Station.
Starmill
18 May 2012
Bolton
To say nothing of the rather large number of km north of the border that will be in scope in that time.
snowball
4 Mar 2013
I would hope it will be running very hot for the next 20 years, by all previous standards, if we are to decarbonise the railways.
If the government is really serious about decarbonising the economy, many industries will have to be totally transformed. The government shows no sign of understanding this.
SuperNova
12 Dec 2019
The North
I may be mistaken, but neither the PM nor Government has ever said they would build a new line all the way from Manchester to Leeds, or via Bradford, or into Liverpool. What they did say is that they would build Northern Powerhouse Rail between Manchester and Leeds. And so it is. NPR is just a badge.
I’m no spokesperson for (even a fan of) this Government, but in NPR terms they are making a huge commitment that is consistent with their long term objectives.
Indeed - The Tories have gone back on their Manifesto pledge on HS2. However on NPR, it was only. "We will build Northern Powerhouse Rail between Leeds and Manchester and then focus on Liverpool, Tees Valley, Hull, Sheffield and Newcastle." No mention of Bradford, that came from TfN.
Page 29 for clarity: https://www.conservatives.com/our-plan/conservative-party-manifesto-2019
Jozhua
6 Jan 2019
The "Integrated Rail Plan" would be better described as the "No Idea, Can't Be Arsed".
I was expecting detailed plans of expected service patterns in 2030, 2040, etc. Instead we're left with "we might do this" "could probably do that" "uuuh this should do"...
To be successful, the IRP should have followed a general cohesive strategy, with certain stated goals. I would have chosen the following:
-To increase capacity to cope with the record passenger demand being seen, with scope for selling more, cheaper seats.
-To modernise the railway to make it more operationally efficient, more accessible and more resilient.
-To enable the railways to better compete with road and air transport.
With these goals in mind, I would then build the perfect service pattern. What level of service do different towns/cities need, how fast should they be and how much capacity will be required?
Once this is completed, you should bring the plans back to reality - figure out the most effective way of delivering as much of this as reasonably possible. You can create different plans based on the funding available.
Rather, government seems to have done it all backwards. No concrete plans for the actual service they want to run - they don't even know how fast this Transpennine "Upgrade" will be? There are so many gaps, so much uncertainty in a document designed to bring certainty.
For a government obsessed with controlling costs, they have unwittingly backed themselves into a tricky corner. It's going to be very difficult for the industry to deliver these plans in a cost-effective manner when government cannot commit to anything. Multiple billion pounds have been wasted on designing HS2 east, now with nothing to show for it. Maybe if government should decide what it wants before it does things - once it has made a commitment, it should stick to it.
I am looking forward to getting my hands on a copy of the IRP, if not because I am in need of some new toilet paper.
Apparently down to the wire last night. Sunak and Treasury still seeking cuts to investment.
Usual UK attitude. Long term pain due to short term thinking.
Levelling up in effect means cutting London investment to low levels elsewhere rather than lift elsewhere to London levels. All suffer.
Can't be like other nations and have various areas see needed investment can we?
Still, many will play the gov game of North v South rather than ensuring all regions see investment.
Playing the North and South off against each other is a genuis ploy on the side of the government. An indifferent Midlands/North when London sees transport finding cut to the bone is very valuable politically.
At the risk of being slaughtered here, a lot of this proposal makes sense. Yes losing the full eastern arm of HS2 is a shame, but for Derby and Nottingham this is much better, the previous Toton HS2 station scheme to me was of no use to either city, when people want direct trains to their City, not somewhere 10 miles away
Of course it was crazy that the whole of the MML hasn't already been electrified, but at least it will happen now.
Most people don't live in the city centre anyway. Toton was always a compromise, but overall journeys were to be considerably shorter - especially going Northwards to Leeds and beyond, which is currently very poorly served.
Lots of planning was done in the region around maximising the benefits of the location in Toton, now it is to all be binned. Services between Nottingham/Derby will likely also suffer, now that they will have to share tracks with more high speed trains.
stephen rp
25 Jun 2016
Just a gentle reminder this thread is not in the speculative discussion section.
This thread is for discussion regarding the actual proposals in the Integrated Rail Plan for the North and Midlands
If anyone wishes to discuss anything speculative or anything else, please create a new thread, or use an existing one, as appropriate.
It's hard to read the IRP and not speculate about what it could all mean.
We are not asking people to not speculate; on the contrary, we welcome speculation; please do create a new thread if any existing thread don't already cover whatever you wish to speculate about.
A selection of currently active speculative threads that may be of interest can be found below:
We only ask that people avoid speculation outside the speculative discussion section; that's all :)
If anyone wishes to ask us any questions about this and/or provide any feedback, please contact us directly (and not by replying on this thread); thanks :)
Austriantrain
13 Aug 2018
The Most people don't live in the city centre anyway.
I consider this to be fallacy:
1. The sum of users at a station does not only consist of residents, but - in a similar amount - of visitors, who will gravitate towards the city center, because that is where workplaces, shops, hotels, entertainment etc are
2. While it is true that most residents do not live in the city center, they will need public transport to access the station and that invariably (except for really huge cities such as London) will be best towards the center. If you don’t provide access, you exclude anyone that doesn’t have a car, which at least on environmental purposes is self-defeating (quite apart from the fact that a lot of drivers will, once in their car, simply drive through to their destination instead of changing on to the train).
daodao
6 Feb 2016
Dunham/Bowdon
I have now had an opportunity to read the IRP in more detail. My comments are as follows:
  • Proposals to serve the East Midlands and Sheffield, which are based on the southern part of the previous HS2 Eastern leg plans. These are an improvement over previous proposals because they provide direct fast links from London to Derby and Nottingham city centres and a new fast link from Birmingham to Nottingham, as well as being linked with full electrification of the MML. The proposed HS2 service to Chesterfield and Sheffield is similar to that previously proposed. I welcome this element of the proposals and there has already been detailed planning, but the timescale for implementation seems overlong.
  • Proposals for the HS2b western leg extension into Manchester city centre, with a new station at Hale Barns (close to but not at the Airport), which are linked with the new NPR high-speed line from Warrington BQ LL to Marsden linking into existing lines at these points. The HS2 extension has already been planned in detail, but the proposed NPR line does not have previous detailed plans and there is no clarity about the actual routes for the sections from Warrington BQ LL to Warburton or Piccadilly to Marsden. Without such detail, it is difficult to estimate the cost of these sections and thus the BCR, and the timescale for achieving the NPR element extends well into the 2040s.
    The document admits that the journey time from Manchester to Liverpool by the proposed devious route would still be 35 minutes and thus not improved. The farcical existing headline journey time quoted of 50 minutes from Liverpool to Manchester (Piccadilly) is misleading, given that the current fastest journey time between the 2 cities is 40 minutes (which was achieved in 1910 by several routes, and was 35 minutes with 1 less stop pre-Covid). Running onto existing lines west of Warrington and east of Marsden is likely to suffer from capacity constraints.
    The value of the HS2 extension from Crewe to Manchester is partly dependent on the use of the section from High Legh to central Manchester by NPR. It will also focus development on an area that doesn't need "levelling up", namely South Manchester and North Cheshire (e.g. house prices in much of South Trafford are already some of the highest in the UK) and on Manchester Airport (inappropriate given the need to reduce air travel because of its adverse effects on climate change).
    I have not previously been convinced about the benefit of extending HS2 north of Crewe, and feel that the NPR element of the proposals has not been assessed properly for practicability or actual cost and will take ages to deliver. It does not improve journeys between Manchester and Liverpool and the benefit of NPR over full electrification of the existing Standedge line and the current TUR works seems dubious.
  • Crumbs to fob off West Yorkshire and NE England, in terms of limited improvements to the ECML, and local transport enhancements around Leeds. The latter includes electrifying the line to Bradford Exchange (but not beyond), and a metro/light rail system, which has been on the agenda for 50 years (but not yet delivered) since Leeds realised that scrapping the modernised 1st generation tram system in the 1950s was a mistake. Frankly, while these developments are welcome (if actually delivered), these areas are being short-changed, to the benefit of their rival (Manchester).
This is true, but in the UK flows are very unbalanced. The demand on HS2 will be primarily for trips from the regions to London and return. Thus, the central London station is important, and so is a non central station outside of London.
In theory, and possibly in Austria. But the combination of Advance tickets, unreliable buses and late first/early last services you often get in the UK, most people will drive to the InterCity station, while those without cars will typically take a taxi or ask a friend or family member to drive them there.
You are missing the point of most of this - capacity. Even if it doesn't speed anything up, capacity for local services on Chat Moss and the CLC will be increased, and Victoria and Castlefield potentially relieved a bit more.
g22
5 May 2014
Talking of West to East Midlands connectivity, are there any improvements to the the painfully slow journey time between Birmingham and Leicester in the pipeline?
The fastest journey time is currently around 50 minutes for just 39 miles. Very poor.
The IRP document text which refers to the Midlands Rail Hub plans doesn't mention Leicester. They will fix Nottingham to Birmingham (rightly) within HS2 so it appears they aren't bothered about Leicester to Birmingham unfortunately.
QSK19
29 Dec 2020
Leicestershire
I think they’d argue that electrification of the whole MML would be a great benefit to Leicester; but, as you say, it doesn’t do anything about Leicester to Birmingham.
I do think, though, that there is a risk of Loughborough being a really big loser of HS2. If creating extra paths from EMP northwards is going to be too difficult, I fear that they’ll take the decision to terminate EMR Intercity services at Leicester (on the basis that HS2 will maintain London connectivity for EMP northwards). That would effectively put Loughborough in no-mans land, leaving it with Regional services only.
Do you think they would actually do this? And if so, would they path 2tph to Loughborough so that it isn’t cut off from the Intercity network?
Austriantrain
13 Aug 2018
If you don’t want to cut off the whole southern MML towards the North, you will have to run services from St Pancras through to EMD to connect with HS2.
BUT this should really go in speculative. Maybe a mod can move it? Thank you!
I don’t doubt that, but if HS2 and NPR do not change this, then leveling-up will be a failure.
This is not only true in Austria, but everywhere on the European continent I have ever been. Public Transport will invariably have a strong focus on the main railway station, even in small cities.
Actually, it is also a rationale used in the IRP itself, both regarding the drawbacks of a Bradford PW station and the advantages of HS2 trains now reaching Nottingham and Derby centers instead of just Toton. So obviously official UK view as well.
It doesn’t mean that there is no need for parkway stations, but in a complementary role, not as main station.
Class 170101
1 Mar 2014
But it can`t be done at any price, Network are probably guilty of gold plating everything meaning electrification gets cut back and will only be rolled out en mass when costs are brought down. the onus is on Network Rail to get its house in order.
But could NR ever get its house in order? Even could NR get its house in order as far as the Treasury and the DfT are concerned? I have my doubts that they could as far as the Treasury are concerned because they want costs of the 1970s and 1980s and probably in absolute terms which wouldn't be achiveable rather than 1970s / 1980s + inflation for reflecting the costs of that period today.
The thing is, UK people don’t want to - they would certainly not accept a Swiss level of spending for rail, at least that is what I suspect - and the UK government obviously as well, because otherwise they would have spent so much more and thought it a vote-winner.
The people of Britain have no knowledge how much is currently spent on railways.
I don't think doubling, or tripling, or even quadroupling transport spending would lead to "rejection" or anything like that.
domcoop7
15 Mar 2021
Wigan
OK. Back on the topic of this thread, i.e. the IRP, does anybody know what the next step is? I.e. does this report get put on a shelf in Whitehall until the next government in 2024 commissions a "Digital Network Connectivity Review" (or whatever buzzword name they give it)? And then says the same things again, with a few tinkering at the edges?
Or are shovels going in the ground in a few weeks time?
What is happening with this plan?
Starmill
18 May 2012
Bolton
I think that the way I would probably phrase it now is that the journey times under the new plan including Sheffield to London Euston have a credibility problem.
And to those who might retort that it is in an official government document, I would say that this increases rather than decreases the doubt about its accuracy, for obvious reasons!
