bb21
Emeritus Moderator
- Joined
- 4 Feb 2010
- Messages
- 24,151
Any Railcard? What's your destination?
Assuming that you held the Via High Wycombe Super Off-Peak Return (£29 adult), the excess would be to the Any Permitted Off-Peak Return (£51.70 adult), so £22.70 each.
There are still a lot of West Ham fans (travelling to West Brom) unsure as to whether they can use the £29 super off peak tickets bought in advance of the landslip on Virgin (without paying extra) or only if they are Advance tickets. ie unclear whether the capital letter in Advance means only tickets for a set date & train or if it is any ticket bought in advance of the landslip.
Another alternative seems to be £29 on London Midland if they are accepted (or to refund Chiltern tickets & buy new ones for London Midland).
Anyone done train - bus - train yet and care to share their experiences?
Just been clarifying over twitter with Chiltern and Virgin the validity of advances purchased before 4 Feb - I was told they need to be used on the closest train possible to the original booking.
There isn't such advice on the Chiltern website, I have been told this will be fed back to be added.
I have an advance for the 0715 from Marylebone on Thursday and asked if I could use it on the 0803 from Euston - apparently this would be too late (there are departures from Euston at 0723 and 0743).
The official "minimum connection time" from Marylebone to Euston is 51 minutes however, so make of that what you will.
I believe that Virgin are settling for "within 30 minutes" of the booked time, to allow for the fact that Chiltern normally have two trains per hour to Virgin's three.
There has to be a cut off, otherwise you could potentially have the situation of someone who'd booked a £6 ticket for the 12:15 from Marylebone turning up at the height of the evening peak from Euston and expecting to travel without paying extra, for example.
They wouldn't, I guess, expect you to go to Marylebone for your timed train then travel from there to Euston.
NRE, the fount of all known wisdom, showed it as such and the guard on the 1555 announced it as such...If this were advertised as an official connection then you have every right to be claiming for Delay Repay.
Ah, I thought the 1810 mentioned in your earlier post meant "instead of 1710".
Except Chiltern don't operate Delay Repay...And if the 1743 runs to time, the delay is 27 minutes according to the published timetable, so no compensation would be due under their Passenger's Charter as that has a 30 minute threshold (as opposed to the one hour trigger on Great Western and South West Trains).
Having said that, in the event of late running, I'm fairly sure bus co-ordinators (not just for Chiltern) are supposed to contact the relevant TOC Control to let them know, so they can make arrangements to hold the train if possible.
Do they not? My bad.
I do remember the threshold being 30 minutes so I must have got confused, especially since for all intents and purposes between 30 minutes and 2 hours, the compensation should be the same.
