The 170s and 185s seem to be unsuited for stopping services but it seems there’s going to be an excess of them.
Would it be prohibitively expensive to fit shorter ratio gearboxes to these long distance trains?
The 185's however have commuter style doors, making boarding quicker. I think they'd find themselves very useful on semi-fast branch lines or on long distance routes still covered by Sprinters. Saw a 156 doing the Norwich-Liverpool run today!
Yeah, maybe even on the local stopping services on the Hope Valley Line? Help with Northerns Pacer replacement and are already used on the route? Doubt it'll happen but would be easy to implement...Given that they have a useful body layout, it may well be worth repowering them with smaller (lighter) engines for local stopping use.
I'm sure ROSCO's and TOC's are mulling this one over anyway. track access charges for the modern DMU's are pretty horiffic compared to sprinters.As with the 170s would a change of gearbox help?
It seems tragic that quite recent DMU units are practically useless while the class 15x units are still set to be knocking about till the mid 2020s.
as for 185's, they do seem a bit overpowered with 750bhp per car-that's the same as a 22x!
maybe removal of the centre car engine/fuel tank would be an option...or build up an extra unpowered trailer car if they need the capacity.
I think turbostar is about 8p per carriage per mile versus sprinters which are about 5.5p.
on rural routes where you're probably only getting 15-20% capacity that is going to add up over the course of a year.
the turbostars could fairly easliy get the flex lightweight bogies(as per 172) which would help.
the old transpennine sets(class 124) were 6 cars(about 240 tonnes) and had 920bhp under the bonnet...max 70/75mph.
assuming you'd need about 50% extra BHP going from 70mph up to 100mph that would imply something like 1500bhp would be enough for a 240 tonne train..should be easy for 185 to keep to that sort of timing...or at least 90mph.
in the olden days even a class 31 +6 mk1's could handle that over settle+carlisle at 90!
(185's are 3 car sets at say 55 tonnes per car =165 tonnes/2250bhp)
The 70 mph was an artificial limit applied to all "1st generation" dmus. Had it been allowed, the Class 124s could probably have reached 80 - 90 mph on level track (albeit with slower acceleration than 185s or even 158s...).
But I would agree that 185s are over-powered - and would be expensive to run - if they were ever relegated to secondary / stopping services.
They already have been. Manchester-Huddersfield & Huddersfield-Leeds stopping services are now in the hands of the 185s.But I would agree that 185s are over-powered - and would be expensive to run - if they were ever relegated to secondary / stopping services.
I’m pretty sure the 185s are the fastest accelerating DMUs I’ve timed them to 60mph at around 70 seconds with my phones GPSI love the idea of a Top Gear type drag race up the Lickey! Can we get an engineering posession for a day? Huge income from the fans paying for lineside seats. But would the 185 win?
As the Settle Carlisle is in very good condition track-wise and equipped for very heavy forces from freight trains, surely, a simple derogation to allow their use on S&C would be in everyones interest, particularly as their power - weight ration is ideal for the long drag and they have aircon that actually works!
I think 185s would be fine on the S&C - the only problem is that the line is relatively infrequent - only a train every couple of hours - so you'd not need many (from a fleet of fifty one).
It's a five hour round trip, so only three trains required for a bi-hourly frequency - plus the whole thing of using 100mph trains on a service that is limited to 75mph top speed seems a little waste (but I appreciate that we'll have a surfeit of 100mph DMUs with all of the 168/170/171/172/175s, so they will end up being used on slower services)
in the olden days even a class 31 +6 mk1's could handle that over settle+carlisle at 90!, a 37 would fly over it!
They might be pretty good at accelerating but at what cost in terms of fuel economy?Whilst the 185s top speed is indeed 100mph, they're also pretty quick at accelerating . They aren't half bad at stopping services too, so the negative at not running at SP or MU speeds is that they can accelerate quicker so the time penalty would be negligible.
If they do find further employment on lines with 60 or 75mph lineside then it shouldn't be seen as a waste. They're a perfectly reasonable unit, good at climbing hills and good at start/stop .
That's relatively common now, they cover for unavailable 158s which are away from PPM work (usually).Saw a 156 doing the Norwich-Liverpool run today!
185s will remain restricted to 75/80mph between Salford Crescent and Euxton. 95/100mph are MU differentials.Bolton to Salford Crescent is 100mph now I think. Someone mentioned it in another thread.
