DarloRich
Why do these trains need a "diet"? What benefit are you trying to achieve? They are good quality, reliable trains that the experts here seem to despise.
I think 185s would be fine on the S&C - the only problem is that the line is relatively infrequent - only a train every couple of hours - so you'd not need many (from a fleet of fifty one).
It's a five hour round trip, so only three trains required for a bi-hourly frequency - plus the whole thing of using 100mph trains on a service that is limited to 75mph top speed seems a little waste (but I appreciate that we'll have a surfeit of 100mph DMUs with all of the 168/170/171/172/175s, so they will end up being used on slower services)
Pretty sure there are sections in West Yorks that are close to 100mph. But then they’d be banging against the local stoppers...
It was four coaches, and they were through wired for blue star multiple working so that both locos could work simultaneously. I don't recall any issues with timekeeping or acceleration.Did the 2 x 37s fly over the S&C for that brief period when they dragged four, or was it three coaches, over the hill? Or was only one of them providing power. Both had engines running but not sure both were notched up. When I saw them they looked ridiculously lumberingly clumsy. But I digress.
Indeed. These units were built to get across the Pennines reliably, and notwithstanding timetable issues they do. Many a time they've powered up the hill to Standedge in heavy snow, wind, rain without a whisper of complaint whereas 158 & others struggle. I've been very happy with their overall performance, if not capacity over the years and would like to see them hang around at least some of the Pennine routes to do what they do best (hence my liking of the idea of them working the S&C).
agreed!
I normally despair about the S&C obsession on this board but think these trains would be good on there. Decent internal layout, first class, nice big windows, trolley space, plugs and enough power to deal with the gradients.
And the Friends of the S&C would love the extra room for their catering, selling their merchandise etc! And as you say the big windows would be a huge tourist sell on that line.
And First Class could be money for old rope if sold as an on-board upgrade for say £5.
Someone didn't read the thread title... "Could they be made light enough for sprinter speeds?"
OK. why? What is the benefit?
Which is not suprising considering that Voyager engines were derated down to 700hp a few years ago.A 185 will out-accelerate a voyager and leave it for dust. Only the voyagers top end speed gives it the edge.
The 185s were built for Transpennine work and the hills on the north south trips on the WCML.
The similar trips are (apologies for the lack of proper names) (Glasgow) - Carlisle - Newcastle, Preston - Leeds, Manchester -Leeds via Rochdale, Settle and Carlisle. I think from the rail press (can't find it, don't ask) the Calder Valley is being cleared for new stock, so the 185s shouldn't be impractical. Most of those routes are used by freight, so heavier DMUs shouldn't be out of the question.
The real point about this debate is that small fleets are real bind and we continue to repeat the folly time after time.
I believe so.Were they, I didn't know that. Is that just to reduce wear?
Why don’t South Western Railway have the 185’s & send the 158/159’s to Trans Pennine?
I’m sure their 100mph top whack would be useful on the Waterloo-Exter route.
I suppose however there is probably some crazy reason why this can’t happen though.
Transpennine are only retaining 185s for the Transpennine North semi-fasts (assuming those are ultimately reinstated), for which they're better suited, and Transpennine South Manchester Airport - Cleethorpes.Why don’t South Western Railway have the 185’s & send the 158/159’s to Trans Pennine?
Six car working of the units between Liverpool and Nottingham would be welcome.So no good for say East Midlands Trains on the Liverpool-Norwich Route?
If a split of the Liverpool - Norwich service ever occurs
Yeah, were it not for what I believe to be quite drastic speed limitations across the fens then 185s wouldn't be a bad fit for the through service. Hence the original topic of this discussion, I suppose!That route is going to be split with one of the reasons being more capacity between Nottingham and Liverpool, but I would like to see the 185's come on to this route but keep running through to Norwich with 6 carriages to Nottingham and then 3 continuing to Norwich.
If you had all services as 9 or 12 carriages would the capacity be the same, also could some capacity be created in the 185s by changing the first class to 2+2 seating or moving it to the front of coach a or c and in standard reduce the number of table seats in order to fit more seats in?Because the capacity is too low due to the poorly designed layout and they don't have gangways.
There are rumours some of these restrictions (across the Fens at least) will be removed for the class 755s. Whether this also affects other heavyweight units remains to be seen.Yeah, were it not for what I believe to be quite drastic speed limitations across the fens then 185s wouldn't be a bad fit for the through service. Hence the original topic of this discussion, I suppose!
Being DEMUs they'd presumably be easier and cheaper to 'Hybrid' than the 168s/170s currently proposed - perhaps that could provide the business case for replacing the engines.
