Simple question if anyone can answer. Im using the 23rd strike day for an example: If a freight is due to leave on the 22nd later in the day, and is subsequently delayed on its run would the service end up getting pulled at first possible location? Just curiosity thinking of caped freights turning up in odd locations/sidings as not to encroach into a strike day
The FOC would reschedule it in the same way they respond to any other event causing a train to be delayed or diverted. Typically if a freight train is going to be over 2 hours leaving (perhaps because a loading terminal has a problem) the FOC would put in a VSTP request for a new path. Which the NR VSTP desk will only grant if it's possible. So a delay before departure in the scenario you ask about would likely result in not departing as NR wouldn't give a VSTP path. There's a lot going on behind the scenes......
TPO
