Railway General Knowledge.
Cowley
15 Apr 2016
Devon
Well this is a total guess but is it the class 35 because all the others were updated versions of earlier designs?
martinsh
27 Jan 2011
Considering a move to Memphis
I'll give it to you for the Sodor link. When did a Shed move to Sodor anyways...?
So what was the right answer then ?
E2 = Thomas
35 = Bear
5MT = ??
04 = Mavis
66 = ??
New Question
Name 5 pre-grouping railways in the UK who electrified part (or all) of their line(s).
Tramways and underground railways don't count.
DasLunatic
11 May 2015
E2 = Thomas
35 = Bear
5MT = ??
04 = Mavis
66 = ??
New Question
The 5MT is Gordon (post-rebuild) and the 66 has never appeared on Sodor AFAIK.
theageofthetra
27 May 2012
Beckenham
If we are talking about the 'proper' books then I don't recall Gordon being rebuilt-it was an A3? Henry was 'rebuilt' only to get around Awdrey's frustrations with his earlier illustrators errors and inconsistencies -from a Greenly Atlantic to a random 4-6-0 I believe.
LBSCR
LSWR
L & Y
NER
LNWR
These were electric pre grouping but not sure thats what you meant?
Grimsby & Immingham
Liverpool Overhead
Calthrop
6 Dec 2015
What was the heaviest 4-8-4 ever built and what unusual feature did it have?
The USA’s Atchison, Topeka & Santa Fe Railroad had many examples – in, by its reference, several different “classes” – of basically very much the same type of 4-8-4; built by Baldwin, between the 1920s and 1944. The final thirty, designated as class 2900, were built in 1943 and 1944: owing to wartime shortages, some different kinds of metals vis-à-vis the earlier batches of the type, were used in their construction. (This was the “unusual feature”.) It caused the 2900 class to be heavier than their earlier counterparts of this type: in fact, the heaviest 4-8-4s ever built.
Cowley
15 Apr 2016
Devon
Did they have some kind of extra high funnel or dome arrangement? I guess (although it sounds silly) it must have been something retractable or there'd be no point having a sign?
theageofthetra
27 May 2012
Beckenham
Correct it had a funnel extension which was raised and lowered via a small piston. Quite a few locos in the US tried various ways of reducing the smoke affecting the crews vision and to improve draughting. Some even had a duct the the length of the boiler where exhaust gasses could be funneled away from the cab in long tunnels. The ultimate solution to the fume problems in tunnels and snowsheds were the famous cab-forwards but even they had aircraft style oxygen masks in the cab . Your floor
Cowley
15 Apr 2016
Devon
I can't think of anything, maybe Calthrop should take it, seeing as he got the correct locomotive type.
Calthrop
6 Dec 2015
If you're sure that's OK -- thanks.
Which LNER branch line connected with an industrial / agricultural light railway system, in total well over twice the branch line's length; with some remaining freight on parts of this complex, continuing to run into the 1980s? And, please give the name of the "industrial" system.
Cowley
15 Apr 2016
Devon
Was it the Ashington system off the Newbiggin branch? They had lots of class 14s up there and a big system.
theageofthetra
27 May 2012
Beckenham
Armstrong Whitworth steam-electric loco? (though I think this may have been scrapped before 1950 unless it survived as a fixed generator in some workshop)
Cowley
15 Apr 2016
Devon
No - but you're in the rigth part of the country
Time for a clue methinks !
This was not a steam locomotive
Was it a type of Tyneside electric locomotive?
theageofthetra
27 May 2012
Beckenham
NER class EE1. It sat unused because after grouping the East Coast electrication project it was built for was put on hold. For quite a time it turned out! What a waste.
theageofthetra
27 May 2012
Beckenham
There was a locomotive built in the US that was conventional (i.e not a fireless) but had no accomodation for or carried a fireman although one was employed. Why was this & what was it the worlds first of?
