Elecman
can an Advance Ticket be refunded due to not travelling because of the severe weather at the intended destination?
This is a very common problem. If you're sure the train wasn't running as normal than you can certainly insist that they should provide a refund with no fees.Thanks, the retailer is saying Advances cannot be refunded full stop and the associated Off Peak ticker for the return can only be refunded less £10 handling fee.
30. Your right to a refund if your train is disrupted and you choose not to travel
30.1 If the train you intended to use is cancelled, delayed, or your reservation will not be honoured, and you decide not to travel, you may return the unused Ticket to the original retailer or Train Company from whom it was purchased, where you will be given a full refund with no administration fee being charged. This Condition applies to all Tickets, including Tickets (such as advance Tickets) that are otherwise non-refundable, and also applies if you have begun your journey but are unable to complete it due to delay or cancellations and return to your point of origin.
If you changed your plans and chose not to travel, but the train still ran as normal, then no.
If the train was cancelled or severely delayed, then yes.
