reverser problem
rbruce1314
30 Jul 2005
up a gum tree
I've just reinstalled BVE4 using a fresh core program then copied all old files from one hard drive to the other.
BUT - now nearly every time I look at the TT, or release/reapply the brakes, etc. etc. the reverser goes to neutral. Happens with all routes and all stocks.
I've asked around all over and nobody seems to have had the same problem. I've even reinstalled again with no change.
I never had it before. What have I done has happened? I'm lost for ideas
Simon_G
19 Mar 2006
The old installation was on the old hard drive - the new installation is on a freshly formatted drive, and the fault appeared immediately.
Right, so you've completely removed the old drive and have a fresh copy of Windows running on the new one? I had an idea that with installations of BVE in two different places, there might be confusion in the registry if the first hadn't been properly uninstalled. Obviously if you've got a clean new registry that isn't going to be so.
Sorry, I can't help except to say that if you look at the Vista thread, some folk seem to be having a similar problem.
