Routing options Waltham Cross to Bath
Discussion in 'Fares Advice & Policy' started by Going South, 26 May 2010.
Thread Status:
  1. Going South
    Going South Member
    56
    22 Aug 2009
    I'm planning on getting a Super-off peak return ticket from Waltham Cross to either Castle Cary or Bath. I have Y-P railcard. Advance tickets are not suitable because I am not sure what day my return journey will be, but I can be flexible on times.
    First of all, Castle Cary is often more convenient for me than Bath Spa, but I can't be sure which I'm better off with until the last moment, and the return may not be the same as the outward journey. I know a Castle Cary ticket is valid via Bath Spa, but is a Bath Spa ticket valid via Castle Cary?
    WLC to BTH (YP Super OP) £36.75
    WLC to CLC (YP Super OP) £40.05
    If travelling to/from CLC I would take direct trains from Paddington and not go into Bath.
    Secondly, what are the time restrictions on this/these tickets - I can't seem to find a definition of Super off peak on the FGW site.
    Thanks in advance
    Rail Forums
  3. b0b
    b0b Established Member
    1,264
    25 Jan 2010
    I don't think you can go to Bath Spa via Castle Cary without a double-back through Westbury, so that means the ticket is not valid.
    Usual advice applies, get a return ticket to the station you're traveling to. If it ends up you travel from Bath but want from come back to Castle Cary, excess the return portion (before you board!), which should be half the difference, or £1.65.
  4. John @ home
    John @ home Established Member Fares Advisor
    5,145
    1 Mar 2008
    SSR Waltham Cross - Bath Spa takes Restriction XC.
    SSR Waltham Cross - Castle Cary takes Restriction WJ.
    Westbury and Frome both have avoiding lines. But the conclusion is correct - to reach Castle Cary you need to double back thorough Bruton, so a Waltham Cross - Bath ticket is not valid.
  5. Going South
    Going South Member
    56
    22 Aug 2009
    Thank you, both
Thread Status:
Share This Page
