scotrail class 156
doningtonphil
18 Aug 2014
Hello
I asked 2 questions in the timetables section about a Carlisle a Glasgow service I saw at Carlisle yesterday. The 2nd question is probably more relevant here.
The Scotrail class 156 made a noise every couple of minutes like several air valves firing, and then again a few seconds later.
What was making the noise?
Thanks
doningtonphil
18 Aug 2014
It seemed to be coming from both vehicles, within a second or two of each other, as if it was supposed to be doing it, like on a timer
455driver
10 May 2010
Was the train stationary in the station at the time?
If so then it is just the water trap (or whatever its called) releasing the moisture it has trapped from the compressed air systems.
doningtonphil
18 Aug 2014
Its defo not the compressor governor. Both vehicles, two distinct sounds pef vehicle at the same time
455driver. Yes it was stationary. Do 455s have a similar system? I know a lot of DMUs have norgren filter systems on their air system, but that doesn't drain every couple of minutes.
455driver
10 May 2010
Not really sure, I would think so as the air supply is pretty much the same on 150s and 455s.
Geeves
6 Jan 2009
Rochdale
I believe it was after the aftercooler mod that the 156s received they started making this sound but how it relates to that component I dont really know
I know the sound like 3 or 4 high pitched air releases within a few seconds of each other.
The Northern ones all make this sound too so I guess the same mod is being done on the Scotrail ones maybe at Heaton.
http://members.madasafish.com/~dysgraphyk/156/class156_underframe.htm
Second to last picture that part is now different, no more pipes, just a smallish box.
driver9000
13 Jan 2008
The small box in the photo is the heating/ventilation box. The Aftercooler pipes are to the left of the image and are still there on the 156s I've seen recently.
doningtonphil
18 Aug 2014
Geeves
That sounds like it. So its a mod on the after cooler. You say the after cooler is the pipes, do you mean that 'helter skelter' of tubing in the bottom photos?
Peter Mugridge
8 Apr 2010
Epsom
I think they do - I've often seen and heard 455s releasing puffs from the valves on the undersides of the carriages.
Also, many years ago I was going out with someone who worked as a tester at the Martonair plant near Farnham; she recognised their valves on the 455s. ( Martonair were later taken over by Norgren ).
simon7929
27 Sep 2011
Stockton South
The Northern units have just started doing this! I noticed one doing it earlier this year and assumed it was some kind of fault! They're all doing it now so must be a new mod!
