Ivo
Hi all,
As the title suggests, I would like to find a cheap Rover ticket that could be considered good value.
This may sound quite simplistic, but I'm thinking more on mileage and coverage grounds than anything else. I had used most stock running today (there are a few exceptions, but nothing especially major), so I'm not epecially worried about that, but I would the chance to find somewhere that is quite cheap to cover and may include various lines I'm not used to. The Cumbrian Coast would be a good example, but there is also the side issue of accessing the Cumbrian Coast.
Ultimately, does anyone have any suggestions? As a general rule, the further south the area the less likely to is to be worthwhile on coverage grounds - but the easier it will be to do. Just don't say a Network Day Tripper
All I ask is that those that are almost done (see here for a rough idea) are not considered unless likely to be unusually cheap or easy. I know it's not a lot to go on, but I'm hoping that someone out there will have an idea and/or some experience that may be just what I'm looking for.
Thanks a bunch
EDIT: Having checked that map again, it's not perfect. With the exception of the routes around Aylesbury, all black lines should be red. (At the time I used black to indicate those I had hoped to do before long, but er...)
Thanks a bunch
