Segregated Toilets on Trains
4 Sep 2009
East Anglia
Last time I used Thalys, I noticed that with each pair of toilets, one is marked male and the other female, and apparently the new EC250 units for SBB will be the same. Whilst the reason for having separate genders in normal public toilets is pretty obvious, I'm curious as to what exactly the point is on a train when it's just individual cubicles, each behind a lockable door?
fowler9
29 Oct 2013
So the toilet seat is always left down on one. Ha ha.
507021
19 Feb 2015
Chester
I completely agree with this, because what would happen if for example a train with two cubicles has either the gents or the ladies cubicle out of order?
The same applies to aircraft, the toilet cubicles on those have always been unisex as well.
Ash Bridge
17 Mar 2014
Stockport
This is nothing new in European trains as I'm pretty certain BRs Met Cam Blue Pullman sets also had segregated toilets back in the day.
Until one is out of action.
I suppose as the urinal is less likely to break (being simpler) that would bring on discrimination complaints.
Mind you, it's common practice in Asian countries to provide female sit-down toilets that are "not for solids" - effectively urinals. Maybe that should spread here, as the plumbing is much less complex. Though I doubt the average British passenger is disciplined enough.
Makes you wonder why we bother with segregated toilets anywhere.
Given modern, enlightened views on gender I personally would in most building settings have a room of unisex full-height cubicles (with CCTV in the common area but obviously not in the cubicles) and a room of urinals. Use whichever you see fit.
The Mk 3 Sleepers have segregated toilets.
I read on another thread that some men considered the berths to be "en-suite"...
I certainly won't be brushing my teeth in the basin any time soon!
Jamescoeby
18 Feb 2017
Noticed that Christmas trains are scheduled to be run out of Antonito over several days in December. Will this be out to Lava Loop and back? Anyone have details yet?
