Severe delays “because a train arrived too early”
infobleep
27 Feb 2011
Absolutely, clearly the signaller hadn't had their coffee yet that morning.
However, still think it's madness to allow a charter in to Waterloo in the morning peak. If there are spare paths (which again is surprising given we're told Waterloo is at capacity) then SWR should be using them for extra services.
Waterloo isn't at capacity though. There are times during the day when trains can't stop at Clapham Junction but that's on the mainline side, not the Windsor side.
Indeed, which means any talk of the station being at full capacity isn't correct.
This is why I posted earlier that although the path is available now it may not be so in the medium term, especially if NR go ahead with their proposed alterations to the normal Windsor side track usage.
infobleep
27 Feb 2011
Just because the path exists from Longhedge junction, doesn’t mean it necessarily exists without conflict through to Hounslow/Twickenham and further.
You'd hope Network Rail would know what was and wasn't possible.
...all of whose trains ran with (on a quick check) maximum delay 15 minutes or so.
I've seen notes put online for delays of 10 minutes and other times when there are delays of 10 minutes or more, nothing.
I do think passengers in cases like this should be informed though. I like to know what's going on myself as I take an interest in it. I. This case it wouldn't do any harm.
infobleep
27 Feb 2011
Indeed.
This has been an advert for the steam service though, which I'd forgotten about.
30907
I've see. Notes put online for delays of 10 minutes and other times she there are delays of 10 minutes or more, nothing.
I looked carefully at RTT.
