Regarding the short codes for L.N.E.R. sheds; in a pre-war 'R.O.', the R.C.T.S. made it clear that the codes it used were certainly not official.
At some point after the grouping the Company introduced the policy of painting the shed name (as well as the loco class code) on the front buffer beam, and the name was abbreviated if lengthy but not 'coded'. I did try, by examination of photos., to compile a list of how sheds were actually rendered but it did seem to rely on the signwriter as much as anything (and I found one where the name was painted upside-down- presumably the beam had been removed from the loco when it was done) Another indication of the home shed was an enamel plate with the name on, mounted inside the cab at the side and at eaves level. I didn't 'cab' locos on shed bashes (normally, hospitality was already being extended) but I think that these may have remained until scrapping but overpainted. They occasionally crop up at
'Railwayman' auctions, and command a high price. One recent example was DF'LINE for Dunfermline, possibly they were standard length to fit pre-drilled bolt holes.
Strictly, prepended - the letters were prefixes. W was also used, up until nationalisation, for locos on the Isle of Wight (Ryde works) - locos transferred across were renumbered.
Interesting that IoW locos not only 'escaped' the 1931 renumbering but, for them, the previous system prevailed on B.R. until 1967, by which time I doubt anyone remembered its origin.
For some reason many ex LNWR locos did not carry smokebox numberplates.
When the LMS was formed, practice followed that of the Midland, with numbers on the tender and only smokebox plates to identify the loco. itself. When this was changed (to cab side number) it seems that everywhere apart from the ex-Midland works then regarded s/b plates as un-necessary. In later L.M.S. days, as well as the ex L.N.W.R. locos, certainly former L&Y and Caledonian ones rarely carried them either; it was only in B.R. days that they re-appeared on the latter two, but never on the former.
Furthermore I believe there were two iterations of changing the ex-LMS smokebox numbers. At first there was an M prefix, which seemed done as a separate piece of plate, then again redone as 5-digit numbers.
The regional prefixes scheme, which lasted from January to about April 1948, were intended to be applied to all region's locos. and so there were ex G.W. locos with a 'W' painted above or below the numberplate. It also resulted in the extravagant S21Cnnn applied to a few Bullies before they were renumbered into the 34xxx and 35xxx series.
Although existing ex LMS locos received the 'M' on the cab side it seems from photos that only newly built LMS design locos received the M prefix to the smokebox plate. I own one of then (pounced when no-one realised what it was). It (obviously) is a block with an 'M' on but it has a tail with a hole in; the left hand bolt securing the s/b plate is removed, the tail slid under it and then the bolt is re-applied. (Once again, that Taunton is leading me off thread
, so perhaps this should all be on a new thread)
