Should some longer rural routes be sacrificed and the money spent elsewhere on the network?
The Ham
6 Jul 2012
If there are a million passengers a year on the highland railways and they cost £100m a year to run then that would be the better part of £100/trip subsidy which is enormous by any reasonable measure.
The point is that you could reduce that cost per trip by making it free to use.
Let's use your numbers as the basis for what comes next.
If we were to make travel free, then that might mean that means the cost on subsidy increases to £111 million. However if you see a 20% increase in passenger numbers the the cost per passenger falls to £92.5.
A +20% uplift in passengers because it's free isn't necessarily that large (rail growth recently had over 8% in some years).
DynamicSpirit
12 Apr 2012
SE London
I'm not convinced that reducing the subsidy per passenger is that much of a benefit if it means the total ongoing subsidy increases. I'd much rather think about what improvements/efficiencies can be made that might attract more people to be willing to pay fares to use the line in order to increase the numbers of passengers while reducing (or at least, not increasing) the required subsidy (even if that means some capital expenditure upfront).
And I really don't like the idea of divorcing passengers from the cost to the extent that passengers don't pay anything and therefore end up with no appreciation of the fact that their journeys do actually cost resources/staff time etc. that someone has to provide for.
MatthewHutton
17 Aug 2024
Oxford
How much lower standard can you maintain the West Highland Line without kicking the freight off it?
Whatever standard the lines were maintained to in the 1960s for less than £10m a year in today’s money.
Likely you could limit to 1960s speeds as well.
Dr Hoo
10 Nov 2015
Hope Valley
Only if it's clearly stated in their manifesto, so they are elected on a specific platform of making railway closure easier. Otherwise, it's surely the sort of thing the House of Lords would oppose bitterly and delay significantly.
Slightly worrying that the Labour Manifesto of 1964 committed to “halting major rail closures” in the aftermath of the Beeching ‘Reshaping’ report. It didn’t seem to stop the closures and quite a few more were added to the original list.
How successful were the Lords in holding those up?
Railway pay was far worse in the 1960s than it is now.
EDIT:
As an example, a driver might expect to earn up to 339 shillings per week in October 1965.
That's £16.95 in decimal currency, or £282.71 per week in 2025. Approximately £14,700 per annum today. And drivers were quite well paid for railway workers.
A porter only got 218 shillings a week, or about £9,450 per annum today.
The Ham
6 Jul 2012
Although it may not necessarily increase the total ongoing subsidy.
As whilst you will increase the numbers of passengers using the line in question, those passengers will also need to get to the line.
Yes many will turn up at a station which is free to use and travel to a station which is free to use, however there will be more than zero of the increase who will go by train to/from a paid for station - which would then offset some of the extra costs.
Yes they are taking up resources, but even if we doubled passenger numbers to 2.5 million passengers (however that assumes we also double the number of passengers at Inverness), however (for capacity reasons) we assume they all travel through from a paid for station that's about 700 people a day (which would be 350 in each direction), which wouldn't really be an issue for most lines, as over a 10 services a day in each direction then that's about 1/2 a coach worth of passengers.
However, even if does increase the cost of the subsidy, the amount it does so by is tiny in the grad scheme of things.
Assuming that the railways were being subsided by £5bn a year (so quite a bit less than the current rate), and there were 10 lines which were around the UK which had an income if £10 million which were then changed to being free to travel lines, the cost increase would be 2% (assuming all the costs stay the same - as the savings would likely be limited to things such as not having to provide TVM's at stations).
Would definitely be a bad headline, but could work if the closures can be redirected into local transport improvements instead of just sucked into general spending. Maybe have a bus service to Wick or Thurso, every hour guaranteed by Parliament. However the line itself should stay since it would be useful as a freight link for timber, nuclear or any other industries that might sprout up in the area. Which limits the savings.
Well quite, if you're maintaining the route for strategic reasons, you may as well run passenger trains on it.
duffield
31 Jul 2013
East Midlands
I suppose the question is if the 1964 government needed to change the law in order to continue the closures. If (as I would assume, admittedly without proof) they just carried on using existing powers then the Lords would of course have been powerless to delay them.
So getting back to today, I think my point is that a law change to make railway closures easier is unlikely, since a government determined to make closures would probably find it easier to use existing powers rather get in a fight with the Lords over it for an extended period before still having to go through some sort of revised process if and when they got their way.
35B
19 Dec 2011
You assume that the Lords would dig in that hard to prevent a change of law that would enable closures. If you look at genuinely consequential legislation (the Rwanda legislation), the Lords were deeply opposed on principle but still did not push things so hard that they blocked the Commons.
Enough powers exist that primary legislation is unnecessary, while if a government did want to close one of the truly rural subsidy sinks (let's say Barnetby - Gainsborough, to avoid the complications of devolution), they have plenty of levers to be able to drive that through should they wish.
Tomos y Tanc
1 Jul 2019
The HoL can only delay legislation for two years anyway. After that the HoC can overule them.
It's all a bit academic though. We are far more likely to see more reopenings rather than further closures. The network has been growing rather than contracting for the best part of half a century by now.
MatthewHutton
17 Aug 2024
Oxford
EDIT:
Ok fair enough. Looks like wages on the railway might have increased 4-5x inflation not 2x like everyone else.
Even so if it was maintained to 1960s standards you would be looking at approximately £40m in total costs to run the far north and west highland lines together.
EDIT £4m was just for the far north so £20m each.
DynamicSpirit
12 Apr 2012
SE London
I'm going to hazard a guess that in the 1960s the trains would have been longer trains hauled by heavy diesel locomotives (maybe even steam in the early part of the 60s?) which would have put much greater wear and tear on the track than todays' DMUs would do, so maybe there's a reduction today from that point of view.
On the other hand, I'd bet the maintenance standards are higher today, and that the lines are more intensively used (for example the local services between Inverness and Dingwall/Tain/etc. which would not have existed back then).
I think the wording in the manifesto was something more mealy mouthed such as "reviewing" any closures.
Nevertheless, it was clear that the public wanted a stop to them, and when Fraser backtracked by saying that he couldn't stop closures that had already commenced under the previous government, a back bencher introduced a private members bill to allow him to. Needless to say, this wasn't supported by the cabinet.
All of this is documented in "Holding the line, how the railway was saved" by Faulkner and Austin (I highly recommend it).
Technologist
29 May 2018
EDIT:
Suggest you use “measuring worth” to do such calculations. If you use RPI inflation to measure anything more than about ten years ago what you start measuring is how much better we have got at making consumer goods.
If you look at relative incomes 339 shillings a week comes out at about £51,000 today.
The relevance of the manifesto is not whether anyone has read it or how many voted for it, it's entirely about that pretty solid convention that the Lords never seriously attempt to block clear manifesto commitments.
And I think rural railway closures are *exactly* the sort of thing the Lords would go to war on, and cause serious delays to. While the government could of course ultimately override them (if they didn't run out of time before the following election), it would bring the whole issue onto the national agenda, get presented as the start of "Beeching mark II" by its opponents, cause other knock-on legislative congestion and be a PR disaster for the government.
Manifestos commitments are only really about 50 years old as a concept. The Lords doesn’t just randomly block anything that isn’t in the manifesto, the Lords don’t generally play politics they block or amend stuff that they as a not particularly representative body genuinely don’t like or where the government is genuinely doing something pretty stupid
Stopping the government closing railway lines that cost the tax payer about as much per passenger mile as putting people in taxis is not particularly popular nor a good use of political capital.
Stopping the government governing is a very good way of getting the lords reformed.
DynamicSpirit
12 Apr 2012
SE London
Minor correction: The idea is a lot older than that. In 1909 the Lords blocked Chancellor David Lloyd George's 'People's Budget' but made it clear they would allow the budget to pass if the Liberals secured a mandate for it at a general election. The Liberals called (and won) an election on the issue, whereupon the Lord voted to let the budget through. Manifestos have been published by the parties, certainly since 1900 (For example, here are the Liberal one and the Conservative one from 1900). I'm not sure if any date from before then though.
Harpo
21 Aug 2024
Newport
Wouldn’t a smarter approach to be to maintain these very rural lines to a lower cheaper standard.
How much slower or less safe would you like them?
And one does have to wonder if guards on the Far North Line pay for themselves via the amount of fare evasion they prevent - I suspect they don't!
Or maybe they pay for themselves by (not exhaustively)
- avoiding the cost of equipping rural lines and/or their rolling stock for DOO operation
- avoiding staffing costs at stations for supporting assisted travel
- avoiding the costs of installing and maintaining power, connectivity and stocking for ticket issuing kit at lots of very rural stations
Etc..
Etc..
The effective cost of providing DOO operated trains with level boarding falls every year as the existing rolling stock draws closer to the scrapheap.
I believe a station on the Far North Line without a power supply would be closed for a significant portion of operational day for a significant portion of the year, as stations without lighting have difficulties with trains stopping after dark (although I may be wrong). Do any of the stations on the FNL lack a power supply for lighting?
Data connections would likely be unnecessary if you used the boarding slip method I proposed up thread, since the ODM suggests the bulk of Far North Line journeys occur to or from a small handful of stations. Given the very low number of passengers the machines would not have to be stocked particularly frequently with new till rolls.
DynamicSpirit
12 Apr 2012
SE London
They can be less safe on these ultra rural lines with low speeds.
You could argue the low speeds are exactly one of the reasons the lines lose so much money. If the speed is lower, you need more trains and more on-train staff to run the same level of service - because of the longer round-trip times which means each train can do fewer round trips per day. AND fewer people use the service because it's less competitive on journey times. From that point of view, a better approach might be to invest to improve line speeds, so you eventually reduce the day-to-day cost of running the line and improve revenue.
MatthewHutton
17 Aug 2024
Oxford
Well that is certainly true with the railway in general.
I would have thought that applies to Penzance to Exeter for sure.
Zomboid
2 Apr 2025
Oxford
Line speeds on the far north aren't bad in general. 60-70 in a lot of places IIRC.
The Kyle line is pretty slow, but it's so twisty that the only way to improve that would be lots of new tunnels, which nobody is going to pay for.
Bristol
on single track routes, changing the run times (making it faster OR slower) will result in needing to cross at different places. If you're lucky, there'll be a loop there. If you're not, then any saving/benefit from the speed change is balanced against the costs of changing the loops.
These routes already have a lot of restrictions for non-Sprinter differential trains as well as generally lower linespeeds. Given BR was driving costs down to the absolute minimum I'm not sure there's much left to take. The case to invest in these lines is similarly bare because there's just so few people to benefit, regardless of any comparisons.
Harpo
21 Aug 2024
Newport
Very succesfully. Guards do the work of all station staff on rural routes and drivers do a chunk of signaller/crossing keepers’ work.
There’s exceedingly little fat left on the bone without affecting train services.
