Signal Passed at Danger
Discussion in 'Railtours & Preservation' started by Chris999999, 28 Aug 2019.
  1. Chris999999
    Chris999999 Member
    217
    22 Jun 2010
    I visited the North Norfolk Line last Sunday, but some services were cancelled because apparently a driver had failed to stop at a signal, and was not allowed to drive any more.
    Are these issues handled by the North Norfolk Line or does some external agency become involved?
    Rail Forums
  3. paul1609
    paul1609 Established Member
    3,415
    28 Jan 2006
    Wittersham Kent
    Depends on the circumstances if its a reportable incident the Heritage Line will report it to the ORR.
    In most cases the line will carry out their own investigation, write a report detailing their actions to prevent a re-occurence and submit it to the ORR for comment.
  4. Edders23
    Edders23 Member
    299
    22 Sep 2018
    Bearing in mind the slow speeds involved and the low numbers of active trains could there be a "serious" spad on a heritage line ?
  5. headshot119
    headshot119 Established Member
    1,755
    31 Dec 2010
    Cardiff
  6. Bertie the bus
    Bertie the bus Established Member
    1,310
    15 Aug 2014
    Considering the Cannon St accident involved a train running at 10 mph and 2 people died I would say the answer is yes.
  7. Cowley
    Cowley Established Member
    6,546
    15 Apr 2016
    Devon
    And also considering that a lot of preserved mk1s are probably not as structurally sound as they perhaps should be...
  8. leezer3
    leezer3 Member
    63
    24 Jan 2006
    Cornwall/ Norwich
    IMHO the Quorn video above isn't quite the same at all.
    It shows the safety system (catch point) working exactly as designed and mitigating the consequences of the SPAD by keeping the train off the main line.
    Sure, the loco got a little bent, but it prevented the much larger potential issue.
    In Canon Street & Paddington, the objects hit were unintentional, and I don't think can be compared directly :)
  9. Bertie the bus
    1,310
    15 Aug 2014
    So we're all safe as long as the train intentionally hits things then. That's what tends to happen with SPADs; they intentionally hit things.
  10. robert7111a
    robert7111a Established Member
    2,433
    24 Apr 2014
    PTSO or platform depending on the weather
    Forgive my stupidity, but if a signal is passed at danger, why is it not a SPAD? The video at Quorn clearly shows the engine passing a signal at danger
  11. edwin_m
    edwin_m Veteran Member
    16,180
    IIRC the signaller failed to reverse the trap points (they're not catch points incidentally) so couldn't clear the signal. Thinking there was some failure in the equipment they authorised the driver to pass it at danger. I don't think that counts as a SPAD. Perhaps with the better view from the cab of a diesel or electric the driver would have seen the points set wrongly before moving towards them.
  12. pdeaves
    pdeaves Established Member
    2,438
    14 Sep 2014
    Gateway to the South West
    edwin_m is right. If you are authorised to pass a signal at danger, you do not pass a signal at danger! The difference is whether someone in authority (the signaller) tells you to or not.
  13. robert7111a
    2,433
    24 Apr 2014
    Aha that makes sense then - thanks for explaining.
  14. Shenandoah
    Shenandoah Member
    96
    19 Jun 2015
    Thunder Bay
    The initial post says this occurred on the North Norfolk line. Subsequent posts have mentioned other places.
    What is not reported here is were any passengers at risk, or hurt? What, if any, subsequent actions have been taken?
  15. bluegoblin7
    bluegoblin7 Member
    854
    10 May 2011
    OZ / OP
    Different railways classify things like this differently, but it would generally be considered as a SPAR - Signal Passed at Red. On my railway a driver would be expected to proceed at caution and stop short of any points set incorrectly. There were formerly different categories of SPAD depending on what the cause was; this one would, at face value, go down as signaller error.
    And just for clarification (as both terms have been used and are often confused, and no explanations have been given) - catch points are (generally) used to protect sections against runaway vehicles ('catching' them) whilst trap points are (again generally, as always there are exceptions) used to protect through lines by diverting trains away until a route is set ('trapping' them in a loop or siding, for instance).
  16. paul1609
    3,415
    28 Jan 2006
    Wittersham Kent
    I think the use of the "a lot" is perhaps a little ott clearly in your neck of the woods there has been an incident recently where that is so but on the railway I work on and I would suggest a lot of the others the coaches have structural work done on them that is basically the same as they would have done on BR and many of the overhauls have been pretty substantial given the age now of the MK1s.
  17. The BIgman1234
    The BIgman1234 Member
    44
    12 Aug 2019
    I always tell the driver to stop short of the points and tell him to check they are in the correct position for the move . Even if the route has been check a dozen times .
  18. edwin_m
    16,180
    However even an as-new Mk1 is less crashworthy than anything in day-to-day service on the main line.
  19. CockneySparrow
    CockneySparrow Established Member
    1,054
    14 Aug 2012
    Stratford
    Yes quite easily, its single line for starters, what if theres another train coming in opposite direction
    Or if the points aint set, could be a derailment
  20. Edders23
    Edders23 Member
    299
    22 Sep 2018
    I think that could be said of many heritage railways maintenance is done to a high standard on most lines
  21. Paul Hitchcock
    Paul Hitchcock Member
    143
    13 Sep 2018
    That would explain a lot about the sequence of events as shown on the video but what puzzled me at the time and still does, was why there appeared to be a slow reaction from the footplate after the first tender wheel left the rails.
  22. leezer3
    leezer3 Member
    63
    24 Jan 2006
    Cornwall/ Norwich
    IIRC they overshot the stop board protecting the foot crossing at Sheringham.
    The crossing gates are always closed when a train is approaching (to protect against this scenario), so as far as I know minimal to no risk.
    Can't comment on actions etc.
  23. robert7111a
    2,433
    24 Apr 2014
    Perhaps we should wait until a) the MNR has carried out its own investigation and b) wait for the report if it is deemed appropriate to appear in the public domain
  24. 2HAP
    2HAP Member
    326
    12 Apr 2016
    Hadlow
  25. Belperpete
    Belperpete Member
    580
    17 Aug 2018
    That is not my understanding of what happened. I recall that there was a misunderstanding between the signalman and the loco crew, with the driver believing he had been authorised to pass the signal due to the fireman incorrectly relaying the message from the signaller. Which would make it a SPAD.
    However, a SPAD is a SPAD, whether it has been authorised by the signaller or not.
  26. ComUtoR
    ComUtoR Established Member
    5,841
    13 Dec 2013
    Can you explain this further please. I really don't understand your comment and neither do I believe its accurate.
  27. pdeaves
    2,438
    14 Sep 2014
    There is a difference between a SPAD and a SPAR (signal passed at red). It's down to authorisation.
  28. BRblue
    BRblue Member
    222
    13 May 2015
    Sunny Sussex...
    I think you'll find it's not... a SPAR is when a train has passed a signal at red due to a reason apart from driver error.
    A signaller putting a signal back in front of a train or a change of aspect (green to red) and the train is to close to stop... if it then passes said said signal at red it is a SPAR.
    Nothing to do with authorisation.
  29. Bovverboy
    Bovverboy Established Member
    1,410
    1 Dec 2013
    Perhaps the crew fell over?
  30. Flying Phil
    Flying Phil Established Member
    1,074
    18 Apr 2016
    Not an expert at all, but the controls on a steam locomotive are very crude devices mechanically and it is the skill of the drivers to get a smooth operation. To get the steam brake or vacuum brake to have an effect is a matter of several seconds, unless they are already being gently applied.
  31. Paul Hitchcock
    143
    13 Sep 2018
    It was going very slowly. Have another look at the video.Signal was right by the box but there was no evident flagman. As I said before, all very mystifying.
Share This Page
