Smartcard Fulfilment
Benjwri
16 Jan 2022
Bath
While travelling yesterday I noticed that GWR have enabled the purchasing and loading of single tickets to their smartcards via their app. This change hasn't been advertised anywhere, and all information I can find still claims only season tickets can be bought and loaded from the app. I did try it and all seems to be working, I purchased a CDR Off Pead Day return from Didcot to Reading with a railcard discount, loaded to the smartcard fine and operated the gates at Reading without question (Didn't try Didcot as was a purchase to extend another ticket so I could travel via Reading and avoid disruption).
However when looking at this I've become rather confused as to what controls smartcard fulfilment. I've used a C2C smartcard and app for a while now and become familiar with what I can use a smartcard on. On there most flows are available, and I can get any type of ticket on most flows except certain ones like Bath to London. This has always struck me as odd anyways, since smartcard tickets are available to London and Bath individually, and on longer journeys.
On looking at the GWR however I have become more puzzled, as it has an even more limited selection of smartcard fulfillable tickets. As far as I can tell this is not due to ticket type, and I can get any type of walk up ticket to show available. To give an example C2C will happily fulfil a Bath Spa to Goring and Streatley ticket on a smartcard, however GWR will not offer the smartcard as an option. I am unsure why it's enabled on one but not the other? Are they getting data from different places? This is a GWR priced flow, so I don't see that would be an issue, and GWR will offer smartcard tickets to other destinations from both Bath and Goring.
Wallsendmag
11 Dec 2014
Basically each TOC has access to the Retail Control Service (RCS2) in this they can enable or disable whatever flows they wish for whatever fulfilment type. All TIS should take a RCS2 feed and sell tickets according to the data contained in it.
CyrusWuff
20 May 2013
Not that it applies to Smartcard fulfilment, but the well-known caveat to this is that Trainline have a habit of ignoring RCS and doing their own thing, so you get things like tickets for cross-London journeys being issued as an e-ticket, which are subsequently rejected by London Underground staff.
Wallsendmag
11 Dec 2014
Hence the "Should"
Benjwri
16 Jan 2022
Bath
So is the suggestion either C2C or GWR ignoring this if one offers a flow and the other doesn’t? But then C2C don’t offer them on every flow, so the only thing I can think of is GWR are manually stopping their system from selling smartcard tickets on certain flows, but not sure why.
Wallsendmag
11 Dec 2014
I didn't think normal walk up tickets with a validity of longer than a day were supposed to be enabled. So if all walkup tickets are available on the C2C site that could be an error. Checking on my test tablet I can only see SVS plus season tickets enabled for Smartcard fulfilment.
OscarH
15 Sep 2020
Crawley
What's the reason for not enabling period returns?
OscarH
15 Sep 2020
Crawley
Unless you have a fully gated system they are wide open to abuse.
Why are smartcards more open to it than CCST or e-ticket, can a guard not write a scan to the card with the phone they check them with (similar to scanning an e-ticket or putting a date on a CCST in biro)?
If not that seems a completes and utter failure in the spec
Wallsendmag
11 Dec 2014
Not unless the checking device has that function which most don't. Smartcards are great for Seasons and Travelcards but not much else.
Mike395
23 May 2009
Bedford
GTR haven't even got their Super Off-Peak day tickets e-ticketable yet (at least not on their MML route) - so I suspect my use of Smartcards for Day Travelcards is some way away. Really needs to be some direction from the industry as a whole to standardise fulfilment for equivalent tickets across the entire country, or people just will get confused and stick to paper/e-ticket even where a Smartcard is more suited.
Benjwri
16 Jan 2022
Bath
Not really a failure, it's just nigh on impossible to have a normal phone handset perform this function so you're looking at something vastly more expensive. With a perfectly acceptable and actually better alternative in barcode it's an unrealistic expense
I can’t think of numerous ways this could be achieved for no extra cost. When the standard was created we could have had a field for scans. Both the RPI devices capable of reading the cards and gatelines are able to write to a smartcard. Or the scans could be stored in the cloud in a similar way to e tickets already are, in fact they could probably use the same database.
OscarH
15 Sep 2020
Crawley
I don't know the ins and outs of NFC, I'd always assumed there was nothing stopping a phone writing data as well as reading it, but maybe not then.
Even so, storing scans in eTVD rather than on the card as Benjwri says should be possible without much effort and allow this
I personally do prefer e-tickets (though other barcoded tickets like m- and s-tickets are terrible), I just don't see this argument for neutering smartcards
Ediswan
15 Nov 2012
Stevenage
As best as I can tell, in general, NFC equipped phones can write to smartcards. GTR say, in relation to The Key (their emphasis):
It is now even quicker to load your tickets to your Smartcard with our app, allowing you to reduce the time spent at the station.
https://www.greatnorthernrail.com/tickets/the-key-smartcard
I suspect @Wallsendmag has something else in mind that a normal smartphone can't readily do.
Gaelan
3 Apr 2023
Edinburgh
Other examples: the Scottish government has an app that loads the under-22 bus pass onto Young Scot cards (produced before the start of the scheme; new cards don't need this step), and the Paris RATP's app can load tickets onto a Navigo card.
Wallsendmag
11 Dec 2014
The records of use aren't kept on the card, ITSO Part 11 allows loading and updating of a product on a Smartcard by a mobile device. But use records need to be sent to the TMS which involves the use of an ISAM , that's where the problem lies.
kkong
8 Sep 2008
Transaction Management System and ISAM (an acronym for indexed sequential access method)
Actually "ITSO Secure Application Module".
It's the bit they need to keep as controlled as possible to stop them falling into the wrong hands, and they don't publish the spec of how it works internally.
Haywain
3 Feb 2013
I'm guessing that is what makes the use of mobile phones a problem.
MrJeeves
28 Aug 2015
Burgess Hill
How come? The phone would be able to read the smartcard number and report a scan through the internet to a central database perfectly fine. This could be through an API that then relays the appropriate info to the backend system in whatever format is needed.
Any modern smartphone with NFC can read ITSO smartcards and write (with the appropriate keys) to an ITSO smartcard, too, just not update the usage of a product.
I would argue that scans wouldn't need to be recorded on the card itself in reality (just like how e-tickets work), but that is what the original question was.
FenMan
13 Oct 2011
A slight digression from the original topic. I have a GWR Touch smartcard, but I find the GWR app a total pain to use.
Question: Can I purchase a ticket via the C2C app (for example) and load it onto the GWR Touch card via NFC as normal?
Bungle965
Buses & Coaches
2 Jul 2014
Calder Valley
I'm fairly certain Avanti have the vast majority of their flows enabled for most ticket types except Advance, excluding of course Cross-London.
WebTIS retailing is restricted to a TOC’s own cards due to technical constraints
