DynamicSpirit
I've just got back to Abbey Wood from central London. SouthEastern were completely disrupted so I used the DLR to Woolwich Arsenal - which was running flawlessly, and there changed onto a very late running SouthEastern train which was crawling along very slowly for safety - and with some very obvious sparking from the 3rd rail that was visible even from inside through the windows.
That got me wondering why the difference. When I got home I did a quick flick around departure boards, to find that most TfL routes (tube, DLR and TfL rail) were running normally with only the Overground badly affected. By contrast, most national rail lines in London were heavily disrupted - from what I can see, only the Fenchurch Street, Moorgate and Kings Cross routes anything close to normal (this was half an hour ago, so might be different now).
I'm not trying to do a NR-bashing thread, but am curious to know why there are such big differences in the snow-resilience? What is it, for example, about the DLR that enables it to run perfectly when the nearby SouthEastern lines can't? Ditto for underground lines (I realise they are underground and therefore protected from the weather in central London, but most of them have very long above-ground sections out of the centre, which you'd naively think ought to make them as vulnerable to the weather as national rail).
