snow
30 Jun 2006
Hi,
Best way to get the 'snow' effect is to change the little pictures found in the train file.
C:\Program Files\mackoy\BVE4\Train\cl156_Pro\d3d\...
there you will raindrops, its just a case of making them snowflakes.
To activate the snow in the route (to hit the window) check the codes at www.bveroutes-trains.co.uk
As for the 'snow' effect route, you will need to change all the objects to make them look like snow.
Kind Regards,
The Snap
10 Jun 2005
To get that effect, as Zane said, it's down to the train and not the route at the moment. If a train has ran drops in it, and the .beacon 21;0;0;x (x being the intensity of rain – 70 being usual) command is used, ran will appear on the windscreen.
However, should a train have snow flakes instead of raindrops, then snow would appear.
It is therefore up to train authors for snow, and not the route authors.
16 Dec 2006
In France (Limoges)
But then it could be possible to substitute the raindrops in the d3d folder with snowflakes or put a mixture of both or even other things (falling trees for example!). Notice also the Birmingham X-City which, if I remember well, doesn't add things to the cl 323 folder even though it includes a few routes with snow.
