Sound files
Dennis
8 Aug 2005
Trowbridge
Was going to add some announcements to a route I am making but am concerned about file sizes. A typical announcement listing station calls is ~500k and causes a noticeable delay when it is about to play.
By the time I have got all the announcments in, the total size of the sound files is going to be greater than that of the objects!!!
Anyone think of a way of making .wav files smaller or are there alternative file types around which can be used?
T
Tom
Guest
BVE only permits .wav, but using Sound Recorder you can compress it a bit.
I use Audacity (search on sf.net), it allows a number of different compression types to try. :)
Coxster
9 Jun 2005
You could instead make an additional file that includes extra, non-essential announcements and a seperate route file that uses them. Then it is up to the person whether they download a large sound file or a small one.
Tom B
27 Jul 2005
Alternatively, package "null" sounds with the same filenames as the real ones with each route, and include the real sounds as an alternate download.
Dennis
8 Aug 2005
Trowbridge
Like the null sounds idea, although I was doing versions with and without the announcements anyway.
TBH, never really thought about download time for people on dial-up, I was more concerned about maximising the route performance - large announcements do seem to cause noticeable jerkiness.
Will check out the wav editors, Thanks.
