Southeastern Not HS1
Robinson
1 Aug 2010
Helensburgh
Quick question here. I have an off peak day return London Terminals to Ramsgate (with 16-25 railcard), route Not HS1.
For the return, I was thinking of using a 395 to Canterbury West, then switching to a 375 going on to Charing Cross.
Is this valid? I have a gut feeling it is but might as well check.
atomicdanny
7 Mar 2010
Kent, UK
It should be Valid on Ashford - Ramsgate or Dover and as I believe Gravesend - Faversham onwards. It only needs a HS1 ticket where the train uses HS1 (Ashford - St Pancras and Gravesend - St Pancras)
edited (remembered that it says about the HS1 Ticket at Gravesend and not ebbsfleet from the last time i travelled)
Yes, this is not using the HS1 route. This is the 'classic' route.
Robinson
1 Aug 2010
Helensburgh
I just wanted to be sure that it was nevertheless valid for use on a Javelin train on the Ramsgate-Ashford section - which you and atomicdanny have kindly clarified. Thanks, folks.
One other thing, actually - I assume I am allowed to break my journey at Canterbury on the way back?
