Southern Class 455 Withdrawal
Razorblades
17 Dec 2021
Sutton Coldfield, West Midlands
I’m also fairly certain that the Class 73 can’t be used to Newport as I don’t believe it can run for too long without third rail but I’m not sure, the way 73’s are powered is something that has confused me.
Be confused no longer! A 73 is an 'ED' - or electro-diesel - and as such it roves the network under diesel power when it's away from the juice-rail.
Southern Dvr
13 Oct 2010
But an original 73/0, 73/1, 73/2 has a very small Diesel engine and will struggle to pull the skin off a rice pudding unaided on most gradients.
sharpinf
1 Sep 2014
thedbdiboy
10 Sep 2011
A 0Z61 Light Loco move from Stewart's Lane to Tonbridge has now appeared... booked out now (1450)
Is that the 73 going back on it's own?
J burge
24 Apr 2022
Newport
Interesting, wonder if it'll be another cancellation today or if they will actually manage to make it to Newport!
Thanks for the info
Unless it's already hooked up and ready to leave I don't know it's a weird one as it's showing no loco return from sims tonight
DustyBin
20 Sep 2020
First Class
Just what I was thinking too. Even LE, I can't imagine it could get very far on its own away from the juice
I think you’re overestimating just how small the engine is. It’s the same engine as used in a “Thumper” DEMU, a three car formation of which is considerably heavier than a Class 73.
Sorry OT but I thought it was worth clarifying.
Class360/1
10 Feb 2021
Essex
thedbdiboy
10 Sep 2011
A Thumper has 600hp available for use per 3 car unit with no requirement to haul a trailing load. The EDs (73s) are useful in diesel mode but in classic form it would struggle up the GWML with 10 on as per a 455 scrap run.
_toommm_
8 Jul 2017
Scrap working:
Will this working pass through West Ealing?… The station isn’t showing on the RTT working.
It should do. Because the path has been put in as a VSTP, only the mandatory timing points will show on it. Ealing Broadway only shows on services that are booked to call at it, or where RTT fills in the time as estimate for passing services.
Class360/1
10 Feb 2021
Essex
Thanks for your reply:)
DustyBin
20 Sep 2020
First Class
Correct, however I was responding to the poster who thought that a 73 running light engine wouldn't get far on diesel.
J burge
24 Apr 2022
Newport
As not showing any movement yet would it still run today but late
Tynwald
18 Mar 2016
It would get there, slowly. The 73 diesel was for shunting yards, that did not have 3rd rail. Originaly they had a primitive ohl, which 71 used to run on. 74 was different story. Much more powerfull paxman engine.
This swansong run appears to have hit its stride now; 69001 has halved its starting delay, and was 'only' +31 passing Maidenhead.
Presumably helped by an abundance of pathing allowances up to that point.
Also, does it really take 50 minutes to enter SIMS, or is the time between Alexandra Dock jn and the scrapyard just very generous?
1 Sep 2018
Malvern to Minffordd
They have to run the Loco round and barriers to propel the first unit in, split the two, and then propel the 2nd unit into the adjacent road. This occurs in the run round loop just outside of SIMS.
warwickshire
6 Feb 2020
leamingtonspa
5Q55 through goring and Streetly approximately 29 late with 69001 455809 455814. and the Van's.
1038 Stewarts Lane to Newport Docks Simms. Very ironic though it Started with the first move of 47727 455838 455839. On a day of thunderstorms and rain on that station and ended a day of thunderstorms with rain but with 69001 and 455809 455814.
On a sad day. Very sad day.
Ending in storming skies.
However R.I.P the Southern 455.
You have served London well.
Southern is no longer the same.
Despite being at the evil hands of the DFT. RIP SOUTHERN 455.
RIP
