Speculation on alternative traction covering the grounding of Class 80x fleet
RobShipway
20 Sep 2009
I believe so
Question is will these be used to lengthen current HST's or form a new set?
I would imagine they will replace a castle set or sets, so that the castle set can be used on services to either Swindon or Reading.
43096
23 Nov 2015
I believe so
No, they were not intended for the staycation set. The vehicles for that are already at Eastleigh for modification and re-livery.
The LSL vehicles cannot be used to lengthen GWR’s sliding doors sets: they are incompatible.
VP185
13 Feb 2010
A reliable source claims that two Hull Trains 802s are on their way over.
I have my doubts over that. The HT 802’s aren’t fitted with ATP so could only go as far as Newbury and would need to be loaded up with the GWR software.
I don’t know if the latter is fairly straightforward to do.
RobShipway
20 Sep 2009
If the Hull Trains Class 802's where fitted with ATP and have the GWR software added, where would that be done?
Could it be something that somewhere like Arlington Services at Eastleigh, would be able to do?
Annetts key
13 Feb 2021
West is best
The above, brings me on to another question. The class 800's when they came out of the factory where in white paint and I believe that they got painted at Arlington Services? If so, would they have had to have the units on jacks to be able to do the painting of the units?
The installation of ATP equipment is likely to be time consuming unless easy provision is already present in those trains.
cactustwirly
10 Apr 2013
They can still run, but at a reduced speed
35B
19 Dec 2011
As I understand it, fitting with ATP etc. is only required for speeds over 100mph; I could imagine that with the need being to run trains - any trains - it'd be better to run under a speed limit than delay for the extra kit to be installed whether at Eastleigh or anywhere else.
irish_rail
30 Oct 2013
Plymouth
The biggest issue with Hull 802s is not ATP but the TMS. Having the GWR routes and stops etc I imagine isn't as easy as a 10 minute upgrade.
Can't see it happening to be honest though would be nice if it did.
CAF397
15 Sep 2010
Lancashire
I could understand more if LNER hired spare Hull Trains 802s as the route is common, at least run them between Doncaster and London.
AdamWW
6 Nov 2012
On the other hand, GWR is much more desparate for trains.
800001
24 Oct 2015
They have differences, so drivers would need a Conversion course before they could drive them.
Qwerty133
7 Oct 2012
Leicester/Sheffield
Which is exactly why sending more similar units there makes no sense. The proportion of units affected at GWR is that much greater than anywhere else that it makes absolutely no sense to send them anymore possibly affected units until it has been definitively established that there is nothing with regards to the GWR infrastructure that speeds up the occurrence of this fault occurring (and which would mean that in all probability that even less units remain in service in the short-medium term).
D365
29 Jun 2012
https://www.realtimetrains.co.uk/train/24508/2021-05-10/detailed
I had speculated in another thread that the class 37 was hauling Mk3 trailers, but thought that it might be loco hauled mk3 trailers rather than HST trailers.
I’m not asking about the coaching stock movement. I’m asking about the speculation of Class 57 haulage.
It wouldn’t be a whole lot quicker to fit, than fixing the afflicted 80x units.
Mac2812
28 Sep 2020
Taunton
Was sat at my allotment in Taunton at 17.20, and a class 37 went passed, with five East Mids mark 4 carriages.... And a Pullman. The Pullman threw me out. Any ideas what this was in aid of? Both the EMR and Pullman aspects
The 'pullman' coach was a Mk2 brake van.
RPI
6 Dec 2010
Going to Laura to be used by GWR in some form
AdamWW
6 Nov 2012
Mk 3?
popeter45
7 Dec 2019
london
the mk2 pullman is being used as a translator van as the HST mk3's dont have buffers or any kind of coupling that the 37 can use
gimmea50anyday
8 Jan 2013
Back Cab
Some TPE 802s being drafted in to assist GWR apparently.
I have heard this internally but nothing official has been announced. It would make sense to make some sets available as out of 19 we currently need only 8 of them and two were stopped so there are theoretically 9 sets available
23 Nov 2015
1. They are not East Mids Mark 3s. They are LSL's.
2. Going to Laira, presumably for (possible) use as cover for the absent Hitachis.
Michael B
18 Dec 2020
Dawlish
I just happened to be waiting for a local train at Exeter St Davids and I managed this quick video:-
