simple simon
BR should have kicked up a fuss when the Met Main Line had its speed limit reduced from 70mph to 60mph in circa 1990.
When Chiltern trains start going to Milton Keynes via Bletchley and the Cambridge Oxford line is fully reopened Met Main Line speeds should not so much be restored as raised, at a minimum to 80mph, if not 90mph. There is too much desire for slowness with respect of travel speeds.
In addition, AWS ramps should be fitted so that mainline trains don't need trainstops. (This should be funded from DfT or Chiltern Trains, not TfL). Then Chiltern could even route their push pull trains with Mk3 carriages via this line.
