Fazaar1889
It's been put forward many times to split the northern line due to some confusion on the line but it has been retorted that this will be complex. Why is that?
Splitting means one line running Edgware-Battersea via Charing Cross and the other running High Barnet/Mill Hill East to Morden. Currently trains from both zone 1 branches run to both northern branches, typically alternating, so that at Camden you have something like 1. Morden-High Barnet via Bank. 2. Battersea/Kennington Edgware via Charing Cross, 3. Morden to Edgware via Bank, 4. Battersea/Kennington to High Barnet via Charing Cross. with occasional trains to/from Morden via Charing Cross. Splitting the line cannot be done without a complete timetable re-write. While this would be time-consuming to produce it would be doable today from a stock and crew perspective. The reason a split can't be done today is Camden Town, it was stated during the consultation about the rebuilding plans that the station expansion was necessary before splitting the line could even be considered, but a split is not inevitable even if the station is expanded."Splitting" the line could mean changing the timetable, or it could mean telling the public that the Eastern Line run from Edgware/Barnet/Mill Hill via Bank to Morden and the Western Line runs from Edgware/Barnet/Mill Hill via Charing Cross to Battersea and Morden, and leaving the timetable exactly as it is now.
Not much more often than the points at any high frequency terminus like Brixton or Walthamstow Central.The points would also be the point. Each of the multiple sets of points in the Camden Town layout is switched after every train, resulting in enormous wear and tear and maintenance bills, the most intense on the network. My understanding is that each set is manually checked and attended to if necessary every day.
Splitting the lines would remove this switching and associated cost. But at the cost of inconvenience for half the passengers. And as others have commented, impractical and dangerous with the current station layout.
So it’d be the same as most metro lines then, and at much better frequency.Surely the problem would be that each northern terminus would lose the through service to either the western or the eastern branch.
I'd have thought that this disadvantage would outweigh any possible advantages.
I don't think it's a massive issue. Crossrail was massively hyped up as a connected railway from Berkshire to Essex and no trains run from Reading to Shenfield (something I thought was appalling at first then realised it's not a big deal to change) You have to change to get from Waterloo to St Pancras, people manage that, and I'd have thought that far more of an important connection than something like Totteridge & Whetstone to Borough.Surely the problem would be that each northern terminus would lose the through service to either the western or the eastern branch.
As said in the other thread, the split will be Edgware-Battersea via Charing Cross as there would then be a main depot on each lineI reckon it'd be High Barnet with Charing Cross and Edgware with Bank, as this is how the service is operated during morning peaks. Catching a train for Euston at Waterloo in the morning, all are bound for High Barnet or Mill Hill.
That was confirmed was it? I suppose it makes sense to have one big depot for each.As said in the other thread, the split will be Edgware-Battersea via Charing Cross as there would then be a main depot on each line
It’s the same as the silly argument that every Southern Region place needs both Victoria and LB, or Charing Cross and Cannon St - because they’ve historically had choices.
Rip the band-aid, as it were - most lines don’t have that choice, standardise and up frequency and predictability.
Similarly get rid of the through trains to both CST and CHX, but don't increase the frequency of trains to compensate, indeed reduce the frequency...Difference being is that on the South Eastern network in particular London Bridge mainline station is that the interchange there isn’t what it was hyped up to be with regular overcrowding and passengers waiting on the concourse because the platforms are too overcrowded, you now have signage that separates CST, Thameslink, CHX and Southern passengers apart, which again was never the plan.
The passengers in this regard were right, seeing the disruption SE has had since December.
The Northern line split probably will never happen, much like the Bakerloo line being re-extended to Watford by 2026
I think their point is, that someone boarding a train at Stanmore, who wishes to travel to Morden, must change. Therefore, requiring someone boarding a train at Edgware to also change in order to reach Morden is not an unusual burden.This simply isn’t true, many areas in London have choices in routes, Stratford now has three routes to the West End, with the Central, Jubilee and Elizabeth lines, in Harrow, the ‘Hill’ station has the Metropolitan and Chiltern routes, and the Wealdstone’ station has the Overground and Bakerloo lines.
Yes, this is more like being unable to go from Ealing Broadway to Edgware Road without changing, which are on the same line but don't enjoy a direct service.Maybe, but Stanmore and Morden are on different line’s already, there’s a big difference between that scenario and traveling between Edgware and Morden.
The rebuilt Camden Town would have full step-free access between all platforms and the surface, and this is another reason why any split cannot happen until after the station is remodelled.Splitting would not be good for disabled people, elderly people and pram pushers. Difficult for suitcase wheelers heading to Waterloo. Because of the way that the stations were built partly on top of each other to be entirely under the road, there has to be steps.
When things went wrong, then Coburg street would send trains down either Bank or Charring Cross, whichever was working and put excess trains in the depots to keep the service working. The same for the northern branches, one would be working but the other closed. This gave a lot of flexibility, you could usually serve the central stations. If you split the lines, then without flexibility, the whole line shuts.
How would a split affect the SelTrac SMC?
Forgive my ignorance, does the Northern already have two rostered controllers at any one time, or is this something that would have to be explored and implemented should a line split be forthcoming before the replacement of the current system? And, whilst it is obviously a hypothetical at present, would you expect one SM to be covering the two lines, similar to C/W&C and C&H/Met?If it were to be in the same SCC, it would be largely no different
That works then - as Bank needs to be at least 30 for the south end. The Edgware-Battersea route could comfortably be 20-24tph until ever extended to CJ / somewhere.The lines are already split northbound in the morning peak, it really isn’t a massive issue to split the lines. In general the High Barnet branch is the busier of the two, so frequencies can differ with a split too.
The only reason why it can’t happen is Camden Town, which couldn’t cope with the interchange traffic. I can’t see Camden Town improving in the short term given TfL’s money problems.
Yep, that’s why they do it northbound in the morning peak, where not many are travelling north of Euston so Camden Town can cope. The problem is it can’t cope the rest of the time. A shame, as it’d be better for the whole line if it could.That works then - as Bank needs to be at least 30 for the south end.
