Standard or enhanced
Luckyflames
12 Feb 2021
Kent
After recently passing my assessment day for Southern. Now awaiting DMI. I was curious to know if they would all be standard passes or enhanced. ? Thanks in advance people. x
L401CJF
16 Oct 2019
Wirral
I'm sure there is a list of all the operating companies and the standard that they require on the OPCs website.
Even if the company you sat assessments for uses Standard, you could well have met the Enhanced score for another TOC.
Keep in mind that not all companies use the same level of enhanced, so enhanced for one company may be lower/higher the enhanced mark required by another.
Also worth mentioning for anybody reading, that if you fail the test for an enhanced TOC you may well have still met the standard mark. This would however mean you only have one chance left to meet the enhanced level.
Hope this helps!
Horizon22
Jobs & Careers
8 Sep 2019
Hope this helps!
There is indeed, you can find it here: https://www.theopc.co.uk/files/ADVICE_Train_Driver_Standards.pdf
As this question has been asked multiple times, it will now be closed.
