Reading through the crossrail disaster it seems the big sticking point has been integration between the Siemens CBTC signalling system and the Bombardier on train management system. I'm not even convinced this is at all working by 'itself', as core testing hasn't started yet, nevermind the other two signalling/train protection systems that it will need to integrate to work on NR lines to Shenfield and Heathrow.
It seems to be pretty crazy to have to integrate two proprietary products like this. You've theoretically got x signalling suppliers and y train manufacturers, which means that you are looking at x * y giant integration projects to do in theory.
I mistakenly thought that ERTMS was the 'standard' for this and everyone would work towards it, a bit like LTE or WiFi. What am I missing here? Is Siemens technology in the core based on ERTMS or is it a totally different system?
Edited to add: it may well be that it is, but it seems to me that there is an enormous amount of bespoke integration work being done, much more than 'tweaking' you'd expect to put two systems together which use the same standard...
