Someone who blindly follows rules because they're told to, in my opinion, isn't a healthy way to go about life.
I would agree, in principle. However there is a difference between blindly following a rule and working to a rule book.
Have you read about Milgram's Study of Obedience?
Yes I have. I have also carried out my own Obedience studies too.
A lot of what is written in the Rule Book should be followed (most is common sense!). But the self-admitting fact it changes twice a year shows that it's not correct to follow everything if you don't understand why you're following it.
I also understand the reasons why it changes too.
Train Drivers should follow rules, come what may is just plain wrong, in my opinion of cuose.
But there is little alternative. How does someone pick and choose which rules to follow and when ? Who defends that Driver in court when they decide to break a rule and it ends up killing someone ? It is very easy to suggest that we should take a more flexible approach to the rulebook and break rules when we decide to but those of us at the sharp end do understand the reality.
The Plymouth incident highlights where rules were not followed, there was a lack of understanding and someone should have challenged the signal
An example of myself bending a rule for what I thought was a good reason.
40(ish) mph into a station. The station is on a curve.
I'm about 50yrds from the 'home' signal and about 75yrds from the station when I get an STOP message on the CSR
For the benefit of the passengers and service I decide to stop at the station instead of using an emergency stop.
As I hit the start of the station I saw a train at the junction (the home signal protects the junction) :/
For all I knew that STOP message was because they just SPADed the signal. Thankfully it hadn't but I didn't know that as I flew past it. If I had used emergency then I would have been half in the station and half across the junction.
It's those scenarios where blindly following the rulebook is the right decision. Any suggestion that it makes me a robot or that passenger comfort should be allowed for or that in someone's opinion the Driver should do what they want is just as wrong.
Another scenario.
Driver running fast, going about 60mph
Gets 2 yellows and puts the brake in.
The train starts to slip so the Driver ups the brakes
The train slips further and the the Driver puts it into emergency.
The train keeps going past the single yellow..
Train heads towards a junction..
Junction signal still at Red..
Driver hits the Big Red Button on the GSMR.
Train flies past the Red.
The Driver followed the procedure perfectly and yet still went past the signal. In this situation the Driver gets fully exonerated. During the investigation every single action that was taken gets looked into. There was a question raised about whether or not procedure was followed to the letter. Any deviation would have cost the Driver and he would have taken responsibility for the SPAD.
If you flip the incident to a different perspective. There was a Driver about to leave the station ahead as he had the junction. The STOP message the Driver sent prevented a collision.
Any decision to not use emergency from either Driver could have lead to a collision. No question, stick the brake in. Sometimes we just don't know what's ahead of us or the potential consequence of not following the rules.
